Almost .. but not quite (starter problem)
adamcfc
PostPosted: 11:27 - 02 Jun 2011    Post subject: Almost .. but not quite (starter problem) Reply with quote
Im having problems with this old banger ive had for 6months or so now, a 2001 Motorhispania RX50. Never got round to riding it properly as i bought a Rieju RS2 Matrix 50 instead Very Happy
Starting, well the starter motor turns the engine over but doesnt actually start the engine. If i bump start it, i have to run fast and for a long time and eventually things begin to happen but its hard to understand. It sounds like it sparks a few times, or very loud misfires, and it will keep doing it irregularly as long as im still running at that speed, loads and loads of smoke comes out the exhaust and theres a black liquid around the exhaust rim.
Ive drained petrol out the bottom of the carb twice so i know petrols getting to the carb, ive taken the exhaust off so i know its not getting restricted stupidly, and ive taken the air box off for now so i know its not getting restricted there.
Any ideas? im just banging my head here and need to get it running soon :/
Any help is much appreciated, thanks, Adam
sandman1976
PostPosted: 11:43 - 02 Jun 2011    Post subject: Reply with quote
Lots of smoke and black liquid around the exhaust rim sounds like piston rings to me.
Broken rings will allow oil to come up into the chamber and gets spat out of the exhaust more or less unburnt.
adamcfc
PostPosted: 11:55 - 02 Jun 2011    Post subject: Reply with quote
mm that makes sense :/ hope not Thumbs Down
Ive just pulled the spark plug out and it fits quite loosely into the HT lead? I pushed the HT lead into the spark plug, and pushed the tip against the engine casing and turned the starter motor over, there was no spark across the electrodes? Should this happen, and how do i check for a spark properly?
serlant
PostPosted: 12:16 - 02 Jun 2011    Post subject: Reply with quote
hows the choke mechanism?
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
adamcfc
PostPosted: 12:26 - 02 Jun 2011    Post subject: Reply with quote
Its like a spring one, so you have to hold it down if you want it on. Its pretty stiff, but the whole bikes in a bad condition so it wouldnt surprise me if its not working, but ive tried starting the engine with the choke held on and with it off.
Is there a way of checking it, do i need to?
adamcfc
PostPosted: 13:15 - 02 Jun 2011    Post subject: Reply with quote
i havent yet, i cleaned the terminals with sand paper slightly, if i put the plug near the engine casing, a spark jumps from the bent electrode to the casing, but i cant see a spark jumping from the centre electrode to the bent one?
Its also a BR8 spark plug, and all teh 50cc engines i know should run on a BR7, so when i get a new plug should i get a BR7?
The Artist
PostPosted: 13:18 - 02 Jun 2011    Post subject: Reply with quote
Very little difference. Either would do.
PostPosted: 13:24 - 02 Jun 2011    Post subject: Reply with quote
Its a two stroke though... they burn oil normally.
Good call on the rings though, a top end rebuild on a two stroke is dead easy. Take the barrel and head off, and examine the barrel. If its smooth then it should be OK, if it is scored then it will need a rebore and hone.
If its smooth, replace the piston and rings, use new circlips and use a new gudgeon pin and small end bearing.
The main hassle during all of this process will be draining down and refilling the coolant.
adamcfc
PostPosted: 00:07 - 03 Jun 2011    Post subject: Reply with quote
ok sounds like the piston or piston rings then. Would broken piston rings greatly affect the compression, thus explaining why i have to run with the bike whilst bumpstarting to just get an odd misfire or bang?
I know how smoky some 2 strokes can be bit this is literally clouds of thick smoke that burst out.
The last post was made 15 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 64.95 Kb
