Bit of an electrical problem with the Superdream.
Carvel
PostPosted: 14:16 - 02 Jun 2011    Post subject: Bit of an electrical problem with the Superdream. Reply with quote
Ok basically while I was out for a ride yesterday I noticed my headlight wasn't working, so I replaced the bulb thinking it was that which didn't work. Having a quick look today, it would appear that my brake light is constantly on aswell.
The headlight switch still operates properly. When you switch it to the first position the sidelight comes on but in the full position the headlamp doesn't light up
The brake light comes on as soon as the ignition is switched on.
Confused
With the brake light switch and headlight switch both being on the right hand side switchgear I thought something might be shorting but I haven't a clue.
Any ideas?
Cheers Ollie.
PostPosted: 15:33 - 02 Jun 2011    Post subject: Reply with quote
A bad earth somewhere. Take any electrical connector blocks you can find apart, check the pins for damage clean them out (I use WD40 or brake cleaner), and put a load of contact grease (or Vaseline if you are like me) in and put them back together. If that doesn't work try cleaning the switches and testing them. If that doesn't work you can try tracing it (or get one of the clever blokes on here to do it for you), by using the wiring diagram.
Carvel
PostPosted: 18:35 - 02 Jun 2011    Post subject: Reply with quote
Right, the brake light was just a sticky switch so thats fine.
My front right indicator now wont work, whereas it was fine yesterday. I've had the indicator apart, cleaned all the earths and connections, changed the bulb and still nothing. The left hand indicators work fine and the right rear works but just stays constantly on. Could the relay be at fault if the left indicators still work as normal?
Still cant get the headlamp to go, cleaned the switch and checked all the connections but cant get anything out of it. Is there a relay or something for the headlight? Cant see one on the wiring diagram.
Would the pass button still lighting it up point to the switch?
LongJohn22
PostPosted: 23:45 - 02 Jun 2011    Post subject: Reply with quote
Start with the basics and check your fuses, its the middle one of the three under the LH side panel for your headlight.
Carvel
PostPosted: 12:43 - 03 Jun 2011    Post subject: Reply with quote
Well I may have been slightly retarded Shifty
The fuses were the first thing I checked, and visually they were all fine, all the elements inside were still intact so I thought nothing of it. Also, for some reason I assumed there wouldn't be a fuse for just the headlight, it would appear I was wrong.
Changed the fuse and it now works Rolling Eyes Laughing Oh well.
Thanks lads Thumbs Up
The last post was made 15 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 49.32 Kb
