Stiff Forks On Gilera SMT 50
scott881994
PostPosted: 13:45 - 03 Jun 2011    Post subject: Stiff Forks On Gilera SMT 50 Reply with quote
About 3 months ago I had to have the fork seals replaced because my old ones were letting oil through. I had new aftermarket ones installed because they were considerably cheaper than the OEM products. The guy at the garage who did the job said the forks will be stiff to start off with but they will soften up. After 3 months they are still as stiff as they were to start with. The handling is quite bad on bumpy areas of road and sometimes the forks push down, lock up and stay in that position. However when it is raining and there is a lot of water on the forks, they aren't stiff at all? I was thinking, could I apply some sort of grease to the forks to stop them being stiff? If so what grease could I use? Thanks.
cb1rocket
PostPosted: 13:51 - 03 Jun 2011    Post subject: Reply with quote
just smear some engine oil over them, or lithium grease.
Aren't the forks bent by chance? This can cause it also, even if slightly
scott881994
PostPosted: 13:54 - 03 Jun 2011    Post subject: Reply with quote
The forks don't look bent, but ive got some lithium grease so I will give that a go. Thanks for your help!
PostPosted: 13:55 - 03 Jun 2011    Post subject: Reply with quote
Sounds like the cheap fork seals are too big. If you are going to put grease on them I would use silicon grease so as not to damage the seals
scott881994
PostPosted: 13:56 - 03 Jun 2011    Post subject: Reply with quote
Ok thanks!
PostPosted: 14:06 - 03 Jun 2011    Post subject: Reply with quote
That wasn't to imply Lithium grease would, damage the seal BTW, but Silicon grease is used on brake pistons to protect those seals.
Plus the lithium Grease I have is toffee coloured whereas the Silicon grease is clear.
The last post was made 15 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.04 - MySQL Queries: 13 - Page Size: 45.96 Kb
