New Project! CB250
StevieMrTD
PostPosted: 10:35 - 03 Jun 2011    Post subject: New Project! CB250 Reply with quote
Hello everyone!
Well after a little recovery I've got a new project. Me and my 1998 CB250 had a little accident. Anyway the right clutch cover has been smashed to bits. I would just go on ebay or to the wreckers but 1998 CB250W parts are scarce, so I was wondering what years/models parts are interchangable with mine? I might even get a whole engine.
Thanks in advance!
Teflon-Mike
tl;dr
PostPosted: 12:08 - 03 Jun 2011    Post subject: Re: New Project! CB250 Reply with quote
StevieMrTD wrote:
Hello everyone!
Thanks in advance!
Am I right in thinking that this is the CB Two-Fifty, the 233cc, single carbed 'Benley' Based twin?
If so its a Benley engine, and the cases etc are black painted versions of those used on the 12v model CD-Benleys, & CM 'custom' or Rebel models, and the CB125TD... though that has twin ignition pickups in the generator cover, and some of the CD/CM covers have holes for the kickstart shaft, if they are off earlier variants.
StevieMrTD
PostPosted: 12:14 - 03 Jun 2011    Post subject: Reply with quote
Yes! The 233cm air cooled single carbed! Not sure if is a Benley based. (I'm a kawasaki man, no idea when it comes to Hondas =D) The problem is honda likes to make "changes" little changes that no one would notice until they buy the wrong part...You can still see where the kickshaft would go on the side cover as well as in the gear case. Any idea of what years are interchangable?
Teflon-Mike
tl;dr
PostPosted: 13:51 - 03 Jun 2011    Post subject: Reply with quote
Not a clue.
As far as I'm aware the crank cases are the same from the earliest 6v Benlies with centre cam chain, around 1975 onwards, hence the flange and stud paterns are the same.
Pretty sure that the clutch mechanism and everything else is pretty much untouched accross the range since they went 12v and dropped the kick starter.
Try here:-
https://www.cmsnl.com/honda-cb250-1998-englandmph_model1477/
or here:-
https://www.davidsilverspares.co.uk/
Find part no for cover you want, then when you find something that looks likely, do the same for the bike offering it up & compare numbers.
nighthawk250
PostPosted: 18:40 - 03 Jun 2011    Post subject: Reply with quote
The part no. may be stamped i/s the cover, it is on the LHS case
andys675
PostPosted: 19:36 - 03 Jun 2011    Post subject: Reply with quote
CMX250 rebel has the 233 engine
The last post was made 15 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 51.34 Kb
