Painting a rad
PostPosted: 16:21 - 03 Jun 2011    Post subject: Painting a rad Reply with quote
Is there a way to do this without ruining it?
PostPosted: 16:42 - 03 Jun 2011    Post subject: Reply with quote
I paint the tanks with plastikote BBQ paint.
I do not paint the core.
MickC
Never done one myself but a quick google search suggests anti rust Radiator paint and give it a good clean and degrease first.
Hope that's of some use
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
PostPosted: 17:31 - 03 Jun 2011    Post subject: Reply with quote
Did you do any prep?
PostPosted: 17:43 - 03 Jun 2011    Post subject: Reply with quote
Aye.
Last one I did I brushed any loose paint off the tanks with a stiff bristled brush and scraped any corrosion off with a plastic scraper. then I washed it with hot soapy water, rinsed it off and blew it dry with an airline. I blew the crap out of the fins with an airline.
I put it in a cold oven (so set to about 90 degrees) for half an hour before painting it which allowed me to get a couple of coats on and dry almost immediately.
The tanks are tougher than you'd think. They are a pressure vessel after all. If you make a hole in them with a stiff brush or a plastic scraper, they were on their way out anyway. I wouldn't go poking them with a screwdriver or anything but they are designed to have water in them at well over boiling point. The caps usually blow pressure into the expansion tank at 15 or 25psi.
I've used a flapper wheel on them before too, just keep the speed low and don't go mad with it.
PostPosted: 17:47 - 03 Jun 2011    Post subject: Reply with quote
I've painted a silver rad black by very lightly dusting it with aerosol can paint. Looked ok and the temp gauge didn't indicate any differently.
The last post was made 15 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 2.54 - MySQL Queries: 13 - Page Size: 49.16 Kb
