eratic idle
nisp
PostPosted: 23:15 - 03 Jun 2011    Post subject: eratic idle Reply with quote
hi,
i have a '81 cb 125 t and I've got a little problem with it, it had this problem before it had a set of new pistons though.
the problem is some times when i come to a stop at say traffic lights, (when the bike is warm, but not in the first few cold moments) it has a tendency to creep up its idle from about 1500 to maybe 2500 or sometimes it goes all the way up to 4K
and this problem is relay getting old and i just want it gone now
so if you got any ideas i would love to read about them, i heard somewhere it could be the condenser??
Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976
MickC
PostPosted: 23:58 - 03 Jun 2011    Post subject: Reply with quote
Could be crud sticking things up in the carb/s pull em off and check the float chambers for deposits. Putting some 'magic bullet' in the tank would help to clear out any crud in the system.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
nisp
PostPosted: 17:04 - 04 Jun 2011    Post subject: Reply with quote
not the carbs, there clean as a whistle!! Neutral quadruple checked today..
MickC
PostPosted: 17:29 - 04 Jun 2011    Post subject: Reply with quote
Are all the hoses connected properly?, if air can leak in anywhere your rpm will increase. Try spraying 'easy start' around the insulators on the carbs (where the carbs go into the head) and see if your rpm increases if so check them for damage and make sure they are clamped tightly.
XX XXXx
PostPosted: 18:48 - 04 Jun 2011    Post subject: Reply with quote
Another vote for an inlet manifold air leak. Test exactly as MickC says.
A second possability is a faulty auto-advance if it's a points model. Check it for broken/detached springs.
nisp
PostPosted: 00:11 - 05 Jun 2011    Post subject: Reply with quote
found the problem i hope, Smile
manifolds were lose, they were tightened to the max but there still must have been a leek so i put blue insta gasket all over the joint and shoved the whole assembly back together and didn't seem to hang around at all Smile
problem solved must have been such a small amount tho
Job done Very Happy it was really starting to get on my nerves Neutral
MickC
PostPosted: 11:04 - 05 Jun 2011    Post subject: Reply with quote
We like simple solutions!
XX XXXx
nisp
PostPosted: 22:48 - 05 Jun 2011    Post subject: Reply with quote
yeah, i guess since the clamps were tight i thought it was something else Embarassed
now i can have the full use of my brand new pistons Twisted Evil
The last post was made 15 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 58.13 Kb
