question about chain
gg
PostPosted: 16:11 - 04 Jun 2011    Post subject: question about chain Reply with quote
I haven't noticed this until washing the bike the other day, so dunno if it's always been like this or not. But there are some tracks on the plastic cover of the swing arm, under where the chain is. After a google, some say the chain usually touches it. So, just wondering, has the chain dug some grooves into the plastic or is it like that usually?
PostPosted: 18:52 - 04 Jun 2011    Post subject: Reply with quote
The chain will have done that. The rubber is there to stop it knocking lumps out of the swingarm.
The chain can hit it in normal running when you go over a big bump and the suspension unloads all the way making the chain much slacker than normal. If it's rubbing a lot, your chain tension is probably set too loose.
gg
PostPosted: 20:32 - 05 Jun 2011    Post subject: Reply with quote
ok thanks, wanted to make sure before i go to a garage about it that it's not meant to be like that.
Slacker24seve...
PostPosted: 20:36 - 05 Jun 2011    Post subject: Reply with quote
Your chain tension should be very easy to set. Check your owner's manual, google it or search around here before spending money at a garage - it will take you 20 minutes, if that.
Banger rallies are ace
gg
PostPosted: 14:24 - 13 Jun 2011    Post subject: Reply with quote
due to the lack of tools, and strength (skinny girly arms, tried to remove the bolt once and no joy), i took it to a garage and they adjusted the chain, all sorted!
DrDonnyBrago
PostPosted: 14:30 - 13 Jun 2011    Post subject: Reply with quote
Biking is going to be very expensive if you take your bike to a mechanic for tasks as simple as setting your chain tension.
Investing in tools is a brilliant idea and quite frankly the only way you will learn to work on your bike. Long breaker bars are a godsend to smaller chaps/chapettes too Thumbs Up .
The last post was made 15 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 47.68 Kb
