YZF 600 THUNDER CAT..CAN I USE R6 USD FORK WITH STOCK YOKES?
URIEL
PostPosted: 16:45 - 06 Jun 2011    Post subject: YZF 600 THUNDER CAT..CAN I USE R6 USD FORK WITH STOCK YOKES? Reply with quote
I have the chance to get hold of a good low mileage Thunder cat and want to know if R6 usd forks would slip straight into the stock TH.CAT yokes?
Also,can the Thunder ace ally swingarm slot straight into the 600's frame without different added spacers?
PostPosted: 17:04 - 06 Jun 2011    Post subject: Reply with quote
USD forks won't fit in RWU yokes... No idea about the rest... probably not.
URIEL
PostPosted: 10:53 - 07 Jun 2011    Post subject: Reply with quote
BLUEX5 wrote:
TL:DR but the answer to both questions is no.
Any idea what would be needed to fit the Thunder ace swinger into the Cat frame?
I ask because i have seen a TRX 850 fitted with FZR 1000 swinger and USD forks,but only at a glance,didn't get chance to ask how it was done.
URIEL
PostPosted: 10:55 - 07 Jun 2011    Post subject: Reply with quote
Do you know of anyone who could make SUZ gsxr 600 usd yokes fit Thunder Cat?
PostPosted: 11:01 - 07 Jun 2011    Post subject: Reply with quote
Normal trick to swap forks and yokes is to press the stem out of the replacement yokes and replace it with the original stem from the bike the yokes are being added to. Will only work is they are about the same diameter though.
Swinging arm might fit OK (Yamaha are generally pretty good at only changing things that need changing), but that is one you will have to measure up. Might need spacers and you might have issues with the sprockets not lining up.
URIEL
PostPosted: 16:38 - 07 Jun 2011    Post subject: TRX 850 SWINGER WILL IT FIT THUNDER CAT....??? Reply with quote
Does anybody know,if a TRX 850 SWINGER will fit the THUNDER CAT 600 frame(desperate now) and if so,what will be required to get them to unite?
Many thanks....... Confused
The last post was made 15 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 52.24 Kb
