GS500E loss of speed and Idle problem!!
MotorbikerTom
PostPosted: 21:32 - 06 Jun 2011    Post subject: GS500E loss of speed and Idle problem!! Reply with quote
So yesterday i went out for a ride on my GS500E with IAM's (about 100 miles to be exact) and my bike was running absolutely fine. On my way home afterwards i was overtaking a car on the a5 and as i passed, the bike slowly began losing speed. Now before anyone says did i close the throttle off by accident, no i didn't, i pulled on more throttle as i thought i may have Embarassed Anyway the speed kept going down until about 55 mph and then it just stayed there and was kind of rocking Confused
I pulled into the parking area and stopped for a few minutes, checked the bike over and couldn't see any visual damage on the chain or anywhere. I got home okay and just took a look over it in more detail and couldn't find anything from my little knowledge of bikes that i could identify as a fault. Now this morning i started the bike and had the choke on for a few minutes, turned off the choke and the engine just sounded like it was going to die. It did, so i started it again and held a little throttle on to try perk it up, off the throttle, then about 10 seconds idling and it dies. It rides fine, i mean i did my 10 mile commute and it ran fine, but as i stopped to lock up my bike i left my bike idling again and it died after a few minutes Confused Shocked
Now it's just a pain!! My inline filter is old and leaking the slightest bit so I'm replacing it with a new one as soon as possible so that's the only thing i can think that may be kind of reducing the flow of petrol to the engine to make the idling poor?? The loss of speed i have no idea about and i know I'm most likely wrong about the idling.
Any information would be much appreciated Thumbs Up
P.S sorry for the life story ^^
CBT: 19/02/11 - Mod 1: 27/03/11 - Mod 2: 01/04/11
'97 GS500E > '03 Hornet 600 > '16 Street Triple 675 > '99 VFR800Fi
Thom
PostPosted: 21:54 - 06 Jun 2011    Post subject: Reply with quote
Partialy dirty carbs leading to dirt in the main jet restricting fuel flow and power?
MotorbikerTom
PostPosted: 22:14 - 06 Jun 2011    Post subject: Reply with quote
Cheers Thom, i'll have a look Thumbs Up
temeluchus
PostPosted: 01:37 - 07 Jun 2011    Post subject: Reply with quote
Try draining the float bowls on the carbs before tearing them off, may just be water in the fuel. This has the effect of starving the motor of fuel as the water is heavier than petrol and settles in the bottom of the float bowls reducing the amount of fuel in the carbies. Kangarooing along is a usual sign and is paticularly acute if there is more water in one carb than the other.
JonnyFoxtrot
PostPosted: 15:23 - 07 Jun 2011    Post subject: Reply with quote
If you turn the petcock to prime does it run fine?
The vacuum gubbins in the frame petcock and the vacuum line on the GS500 are notorious for going bad or being loose and this will cause fuel starvation. Switching to prime will negate this effect as fuel is forced into the carb rather than fed through the vacuum which may be dodgy.
I had similar running problems so swapped mine out for a newer petcock and its been fine since.
'89 Honda NS125F (SOLD) -> '92 Suzuki GS500E (SOLD) -> '03 Kawasaki ZX6R B1H (SOLD) -> '96 VFR 750 RC36 (SOLD) -> '02 Honda CBR1100XX Blackbird
PostPosted: 15:26 - 07 Jun 2011    Post subject: Reply with quote
This before you can anything apart try running it on prime.
It does seem to be the catch all answer on this forum, 'Clean out the carb(s).' Laughing I feel certain people can;t say anything else in the workshop...
sickpup
Old Timer
PostPosted: 15:35 - 07 Jun 2011    Post subject: Reply with quote
I think you are wrong and it's carb icing. Wink
PostPosted: 15:43 - 07 Jun 2011    Post subject: Reply with quote
Oi you, reply to my PM Razz
MotorbikerTom
PostPosted: 21:38 - 07 Jun 2011    Post subject: Reply with quote
Cheers guys, i'll try it on prime tomorrow when warming it up.
Being a nooooooobie, i presume i turn it off before i set off Wink
The last post was made 15 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.16 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 65.4 Kb
