startin when hot
BigGeeking
PostPosted: 12:46 - 07 Jun 2011    Post subject: startin when hot Reply with quote
Hi all im new to this site been on as a guest for some time.
Any way my little 2001-m1 cg 125 has a starting issue it will start in cold
Or first thing in the morning no problem with less than 2 seconds on the starter
And runs really good for a 125 but when the engine is in full working temp and
I stop for a min with the engine off I try and start it but it seems reluctant
To start it can take up to 10 seconds on the starter.
Is it some type of carbon build up Crying or Very sad
I have done the valves to 0.008 it has new oil. I have changed the exhaust gasket
For a copper compression one when I took the clutch cover off to inspect the clutch
And oil pump when I first got it about 2 months ago. It has a new spark plug in and it looked in good condition colour wise so it’s not lean or rich.
Just don’t get why it is doing this or is it just the character of the bike. Question
Thanks in advance peeps Very Happy
Quote Me Happy
PostPosted: 12:48 - 07 Jun 2011    Post subject: Reply with quote
Did you mean 0.08mm on the valve clearances?
BigGeeking
PostPosted: 12:51 - 07 Jun 2011    Post subject: Reply with quote
sorry my bad 0.08mm Embarassed
cb1rocket
PostPosted: 13:05 - 07 Jun 2011    Post subject: Reply with quote
new spark plug, air filter replaced? Its normally points to the sign of needing the basic service done. Normally a new plug cures this. Try adding a touch of throttle when starting from hot. It does help as the mixture is too rich for a hot engine at closed throttle when starting
BigGeeking
PostPosted: 13:25 - 07 Jun 2011    Post subject: Reply with quote
i put a new spark in not too long ago i will recheck the air filter give it a good clean and re oil it i will try some more throttle next time
thanks Shocked
bennell09
PostPosted: 14:19 - 07 Jun 2011    Post subject: Reply with quote
iirc engines run leaner the hotter they get due to technical things i dont/cant be bothered to understand, maybe your running a touch lean then as the bike heats up the mixture becomes more lean thus making it harder to start. the 10seconds on the starter must even out the mixture and allow your bike to start, i had a similar thing on a pit bike a while ago, see what raising the needle/dropping the clip does or if it has any effect atall Thumbs Up
andys675
PostPosted: 14:25 - 07 Jun 2011    Post subject: Reply with quote
make sure the plug is right, a DPR8EA-9
P= projected insulator (tip is longer)
9= 0.9mm plug gap
as a DR8EA and DR8ES will fit and work, but the spark is higher up and smaller
BigGeeking
PostPosted: 15:30 - 07 Jun 2011    Post subject: Reply with quote
thanks peeps
i will give it a go but being at idle will it not be the idle jet Question
9= 0.9mm plug gap
i think i have the plug with the 8 in at the mo if so i will change it
thanks for the replys Thumbs Up
BigGeeking
PostPosted: 15:40 - 07 Jun 2011    Post subject: Reply with quote
ill try tonight on way home i hope so because i know that the bike is ment to run leanish (if thats a word) Mr. Green
BigGeeking
PostPosted: 22:31 - 12 Jun 2011    Post subject: Reply with quote
right fookin bike tryed what all have said and still no joy, tryed to start today wen hot and same so tryed kick start and started on second kick WTF Evil or Very Mad
do you think riding the bike with lights on is taking all the power and its not charging the battery but saying that it starts first thing when cold!!!! Shocked
also the air box rubber has been patched up by previous owner could that have something to do with it Neutral
BigGeeking
PostPosted: 22:38 - 12 Jun 2011    Post subject: Reply with quote
rob yarrr wrote:
yeh they run crap if the airbox rubbers not sealed
only a few quid to replace it
could i spray wd40 when on tick over to see if the rpm speeds up or will i need something more
BigGeeking
PostPosted: 22:46 - 12 Jun 2011    Post subject: Reply with quote
just had a look only £6 from honda
ta mate
Very Happy
BigGeeking
PostPosted: 23:59 - 12 Jun 2011    Post subject: Reply with quote
if i put in a colder plug do you think it will help because the one in now if for town riding and i do mainly dull carriage ways average speed is 50 / 60 mph Wink
BigGeeking
PostPosted: 20:02 - 14 Jun 2011    Post subject: Reply with quote
right have had another look at the plug and it is a 8 gap on the plug not 9 so have got a new one will let you all know how i get on and i have also got a 9 up from 8 on the heat rating so a colder plug as i do a lot of dual carriage ways not much at slow speed or idle i average about 50 - 60 mph over 15 miles so can only do good. lets see how i go
thanks for all the help Very Happy Thumbs Up Dance!
The last post was made 15 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 93.39 Kb
