TZR won't run for more a min
hornetmike
PostPosted: 15:33 - 07 Jun 2011    Post subject: TZR won't run for more a min Reply with quote
this is a fault i have with my 1990 tzr 125 ive had the carb apart and fitted new jets etc and cleaned it out fitted new plug and coil ,it starts fine but after a few seconds it starts to misfire a bit and as you can see it bogs down and will not rev up but it still ticks over
https://www.youtube.com/watch?v=d83uTlAs3Cw
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
hornetmike
PostPosted: 16:04 - 07 Jun 2011    Post subject: Reply with quote
yes tried with a temp tank hanging from celling.
hornetmike
PostPosted: 23:58 - 07 Jun 2011    Post subject: Reply with quote
Its not a fuel supply issue all checked.
The only way I could get it to rev was by putting the circlip up a notch to the thord which drops the need down a bit. now it revs but back fires pops and bangs. Any ideas?
cb1rocket
PostPosted: 09:53 - 08 Jun 2011    Post subject: Reply with quote
rob yarrr wrote:
thats a timing issue then
2nd that, the timing is out of wack and backfiring and all sorts. Also check your 2 stroke oil is pumping or use premix for testing.
hornetmike
PostPosted: 10:19 - 08 Jun 2011    Post subject: Reply with quote
How do you adjust timing on a 88 tzr ?
cb1rocket
PostPosted: 11:34 - 08 Jun 2011    Post subject: Reply with quote
if its CDI then there is not much that can be done, but its worth checking the timing to make sure its not out of wack. If you have the workshop manual then its useful to get a strobe light or similar to check the CDI is not playing up.
Was the bike running ok prior to this?
Have you tried fresh petrol, i meant proper fresh petrol straight from the pump and home straightaway and test it. Mine has water in it and it did exactly the same thing in my GP100, no power and would never run right!
Try a new plug and make sure its the correct one. Some new plugs are known to be duff from new! It can be electrical so make sure nothing is vibrating loose either and the cap on the spark plug is on firmly.
andys675
PostPosted: 21:34 - 08 Jun 2011    Post subject: Reply with quote
if its the timing it could just be the woodruff key, have you had the flywheel off lately?
hornetmike
PostPosted: 00:00 - 10 Jun 2011    Post subject: Reply with quote
thanks for replies turned out to be oil pump, school boy error not seeing that
The last post was made 14 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 68.44 Kb
