| chris vvc |
 chris vvc Derestricted Danger
| chris vvc |
| chris vvc |
| connornrg |
 connornrg Scooby Slapper
| Lipsmoker |
 Lipsmoker Trackday Trickster
 Posted: 20:10 - 08 Jun 2011 Post subject: |
I've used to have a Neos 50, the same as the ovetto
Take off the carb blow the jets out
while the carbs off under the inlet manifold is a reed block two Allen screws take that off you will see little petals hold the block up to sunlight and make sure you cant see ANY sunlight coming through.
A Compression tester could be useful too sticking your thumb in the plug whole is never accurate.
On the right hand side of the scooter you will see a little vent cover take off this cover and you will see your stator the stator will have a little metal strip (this times the spark) make sure the metal strip isn't rusty use some light sandpaper and get any rust off.
Fresh fuel wouldnt hurt either.
As for the Electric start problem i bet you wasnt pulling in the brake was you  ____________________ Four wheels move the body. Two wheels move the soul. |
| chris vvc |
| chris vvc |
 Posted: 21:32 - 08 Jun 2011 Post subject: |
| Lipsmoker wrote: | I've used to have a Neos 50, the same as the ovetto
As for the Electric start problem i bet you wasnt pulling in the brake was you  |
ill have a look at the reed block an stator first thing tomorrow morning also will try and lay my hands on a compression tester aswell.
i have put fresh oil and fuel in today
as for the electric start it was the starter motor, the pulling of the brake still caught me out tho
thanks for your reply mate  |
| Lipsmoker |
 Posted: 00:41 - 09 Jun 2011 Post subject: |
No worries let me know how you get on
| chris vvc |
| thomp1983 |
 thomp1983 Crazy Courier
| chris vvc |
| chris vvc |
| Nope. |
 Nope. World Chat Champion
 Posted: 06:21 - 18 Jun 2011 Post subject: |
If its heat seized then its likely that the rings are buggered.
I wouldn't buy that kit unless I wanted it too seize again though. Its cheap chinese tat. My mates just been through 3 of them in about 5 months... ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
Current: 2011 Yamaha XT660Z Ténéré, 2003 Yamaha YZR-R1 5PW (In Build), 2009 Kawasaki ZZR1400 |
| chris vvc |
| timsmith |
 timsmith Two Stroke Sniffer
| chris vvc |
| chris vvc |
| Nope. |
 Posted: 18:47 - 22 Jun 2011 Post subject: |
| chris vvc wrote: | right then, iv took the head and barrel off to check whats going on, it does not look good, the piston and the barrel are pretty badly marked (piston ring is still on)
what are the chances of it doing damage to the whole of the engine, and not just the top half ?
thanks
chris |
Not a lot. You'd know if the crank had snapped.
The bearings could be shot of course.
Is the circlip still on the gudgeon pin? ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
| chris vvc |
| Nope. |
 Posted: 20:45 - 22 Jun 2011 Post subject: |
| Quote: |
no the crank as not snapped
the bearings look intact
yeah the circlip is still on the gudgeon pin,
i carnt see anything in there what shouldn't be there either. do you think one of them barrel and piston kits should do it then?
chris |
Well, put it this way, you could get one of those kits and it MIGHT be fine. One of my friends has been through 3 cheap chinese kits in the space of 3 months because they keep seizing or breaking circlips.
Having just looked around it doesn't seem as though there are many alternatives so if you do get one of those kits I suggest that you are very careful when installing it and once its running go VERY easy running it in. Dismantle it at 20 miles and check the circlip, then again at 60, then again at 100, then again at 150, then again at 200 all the way too 500 miles when it should be run in. You shouldn't really have too do this but as I say, my friends moped is eating cylinders.
Oh, and take a picture of your bore now and bung it up here. It might not be that bad. ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
| chris vvc |
| Nope. |
| chris vvc |
 Posted: 19:11 - 29 Jun 2011 Post subject: |
Brought a new 50cc top end kit that came yesterday. The old man put the rings on the piston as he said hes done a few back in the 70's
Anyway he's got them on but they seem loose, are they meant to be gripping the groves tightly?
thanks
chris |
The last post was made 15 years, 116 days ago. Instead of replying here, would creating a new thread be more useful? |
