FZR600
fury cage
PostPosted: 21:18 - 07 Jun 2011    Post subject: FZR600 Reply with quote
HI THERE HOPE SOMEONE CAN HELP ME, i have the above bike and i have a problem with it, i was riding along then all of a sudden i had loss of power.... tried to re-start but would not fire up was just turning over... and yes i know i'm a woman but there was petrol in it lol any ideas please .x Confused
1989/90 AND IT TURNS OVER BUT PUMP IS DEFINATELLY WORKING AS I CAN HEAR IT AS ALWAYS
hello there Smile
PostPosted: 22:49 - 07 Jun 2011    Post subject: Reply with quote
Is the fuel pump running? You will likely hear it clicking when you turn the ignition on (if plenty of fuel getting the the carbs then you might not, but often if sat for a while you will hear at least one click).
After that, is it sparking?
jjdugen
PostPosted: 08:52 - 08 Jun 2011    Post subject: Reply with quote
What year FZR? Reg/recs are notoriously bad on these, if i blows it can take the ECU out, even the clocks.
fury cage
PostPosted: 21:54 - 08 Jun 2011    Post subject: Reply with quote
YES ITS CLICKING AS IT DOES WHEN I TURN ON EVERY TIME IF SAT FOR 2+ HOURS
hello there Smile
fury cage
PostPosted: 21:57 - 08 Jun 2011    Post subject: Reply with quote
1989/90 PUT NEW REG ON IT !!! ITS TURNING OVER BUT NOT POWERING UP !!!
hello there Smile
PostPosted: 22:03 - 08 Jun 2011    Post subject: Reply with quote
Check for a spark. Take a spark plug out, put the plug lead on it, earth it against the engine and crank the engine over.
Also does the rev counter needle move at all as you crank it over?
fury cage
PostPosted: 22:15 - 08 Jun 2011    Post subject: Reply with quote
hi there dont have rev counter on it all clocks removed as was not working 2 year ago and have street fightered it now and only have speedo !!!! do you know what size spanner i would need to remove plug as i have to borrow tools thanks
hello there Smile
The last post was made 15 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.01 - MySQL Queries: 13 - Page Size: 52.89 Kb
