KLX 650 HELP. CARB ISSUE.
billybigspuds
PostPosted: 03:13 - 09 Jun 2011    Post subject: KLX 650 HELP. CARB ISSUE. Reply with quote
Just got a klx 650 its m reg. (1995)
its off my uncle it was running mint before it was stood for few month.
whilst stood for few month it was started up every few week till engine warmed up then turned engine off once warm.
well i bought it of him yesterday and just brought it home and put it away as it was to late to start up as i have elderly people living close by and bikes loud with arrow exhaust sysytem.
down to the problem...
it starts up and idles nice but there a lot of petrol constantly coming out the overflow pipe.
ive had carb off cleaned jets and flaot seems to be doing its job.
after having good look at carb and putting it back on the bike,its still leaking petrol from the overflow pipe.
another thing is theres 2 things on the carb where you put petrol pipe on that comes of petrol tap.
well petrol pipe can only go on one i put it on the top one but the bottom one dont have nothing going on it
and the airbox uner the rear mudguard theres a pipe coming off going to no where but it looks like it should go somewhere
thanks for reading the big story haha.
any info will be decent..will get pics up tomorrow
truslack
PostPosted: 09:52 - 09 Jun 2011    Post subject: Re: KLX 650 HELP. CARB ISSUE. Reply with quote
This should be in workshop, but the other spigot on the tap is probably a vacuum hose and should attach to the vacuum take off on the carb, though I'm not sure why it's even getting petrol at all without the vacuum pipe connected.
billybigspuds
PostPosted: 15:04 - 09 Jun 2011    Post subject: Reply with quote
theres just one pipe going to carb and thats the one from the petrol tap.
theres 2 pipes that come from tank to tap then one from tap to carb.
the vacuum part i think sits on the top of the carb well thats got a plug over it.
i will get some pics up now then it will help..
billybigspuds
PostPosted: 15:16 - 09 Jun 2011    Post subject: Reply with quote
heres a pic of the carb.
the pipe conector thing im pointng at is the one thats doing nothing as i use the one above to put petrol pipe on.
pluss under the carb there like a T shape junction thats doing nothng.
thing are not there for nothing hey??
hellbound
PostPosted: 16:15 - 09 Jun 2011    Post subject: Reply with quote
My GN250 leaks fuel from the carb when its parked up due to float not being set right so it floods the petrol chamber in the carb till it comes out the overflow.
check the float level is correct
May you always see the road rising up to meet you and your enemies defeated in the mirror behind.
billybigspuds
PostPosted: 17:00 - 09 Jun 2011    Post subject: Reply with quote
i will look at that today thanks for reply mate.
its just that ive never played with 4 stroke carb before.
shall i get new carb of ebay or try sort this one.
PostPosted: 17:09 - 09 Jun 2011    Post subject: Reply with quote
There are VERY few reasons as to when you need a new carb, are things seized in it? has the body got structural damage? No? Then you don;t need a new carb, get a haynes book of similar and make sure the float height is correct and it is working properly/not sticking.
billybigspuds
PostPosted: 23:52 - 09 Jun 2011    Post subject: Reply with quote
well this is what i think problem is..
look at in the picture above the black thing you put your petrol pipe on well theres one below it that no pipe goes to but it looks like a pipe should go there but once a pipe goes there where does the over end of the pipe go.
whats the vacuum pipe on my carb???
theres one pipe that goes to my carb and thats the one from petrol tap.
billybigspuds
PostPosted: 16:32 - 10 Jun 2011    Post subject: Reply with quote
had carb off again today clean it up for 4th time.
floats seem to be doing there job when you take carb bottom off and check them.
so i put it back on the bike turned petrol on and its just pissing out the overflow pipe when bike started or not
do klr 650 carb fit on klx 650 (are they the same).
theres 2 on ebay at £40 is it worth me buying one.something not right in this carb and i cant find no info on what it is but can find people with same problem.
truslack
PostPosted: 02:09 - 11 Jun 2011    Post subject: Reply with quote
Have you checked that the floats actually float, the condition of the float valve needle, and that the needle height is set properly?
The last post was made 15 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 64.52 Kb
