Help with wiring connectors!
Jarlak
PostPosted: 21:00 - 09 Jun 2011    Post subject: Help with wiring connectors! Reply with quote
(Ref Honda cbf500)
I have an urgent question that I need to sort before my MOT tomorrow! I’m not great with electrics. I had to replace the rear brake pedal light switch. I bought a new one but for some reason it has come with a female connector.
The wiring hub on the bike is also female. What should I do? What is it even called and can you get adapters?
cheers
PostPosted: 21:18 - 09 Jun 2011    Post subject: Reply with quote
They tend to be model specific.
As a temporary measure for your MOT, you could cut both connectors off, strip back the wires, twist them together and tape over them with PVC tape or shrinktube.
EDIT: Scrub that. If you get a fine bladed screwdriver, you should be able to wiggle the connectors out of the plastic molding (poke it down between the plastic and the wire to push down the little barb on the connector while pulling the wire). Tape the connectors together for the MOT. You can push them back in after.
If you want the exact connector block, you'll probably have to get it off a honda dealer along with some mini connectors to fit in it.
If it was me, I'd cut both connector blocks off and replace them with insulated bullet terminals.
HoggyF
PostPosted: 21:24 - 09 Jun 2011    Post subject: Reply with quote
Why not cut the old male connector off the faulty switch with say an inch of cable left on it, strip back the outer then cut off the female connector off the new switch, strip off the outers again, twist each together then solder on the old male connector, seal up with self amalgamating tape (get it from elec wholesalers - much much better than insulating tape)
Thats a long term fix that you can forget about.
PostPosted: 21:36 - 09 Jun 2011    Post subject: Reply with quote
Or spray the old switch liberally with WD40 and wiggle it back and forth until it starts working again. It is unusual for one to actually break, it's normally just a bit of muck and corrosion in there. A CBF500 is a relatively recent model and I wouldn't expect a rear brake switch to have let go in this short a time.
kramdra
PostPosted: 00:29 - 10 Jun 2011    Post subject: Reply with quote
dont just twist the wires together Rolling Eyes
tape is fail. use heatshrink over hotglue.
use chocky block. Do properly and it will be far more reliable.
PostPosted: 00:37 - 10 Jun 2011    Post subject: Reply with quote
https://images.cryhavok.org/d/16996-2/Can_t+Tell+if+Trolling.jpg
The last post was made 14 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 49.39 Kb
