Removing Rear Wheel, CB500
AHurdwell
PostPosted: 12:32 - 10 Jun 2011    Post subject: Removing Rear Wheel, CB500 Reply with quote
Hi All,
I've found a place that will fit a rear BT45 for me for £77 but they will only do it to a loose wheel.
So the plan is to ride there with some tools, remove it for them, get them to fit the tyre and then refit the wheel.
Is there anything that I could expect to go wrong, and is there some tools that I will definitley need. Othere than a socket, breakers bar, and a torque wrench?
Quote Me Happy
PostPosted: 12:35 - 10 Jun 2011    Post subject: Reply with quote
Have you taken it off yourself before? If not definitely have a go before you go so you know you can do it with your tools. Sometimes something to knock the axle through is useful.
neil.
PostPosted: 13:55 - 10 Jun 2011    Post subject: Reply with quote
Take note of where any spacers go with respect to any other bits, in fact, what I do is thread any bits the spindle goes through, back on to the spindle in the order they go on, and the right way around. The CB500 has a drum brake doesn't it? You might find you can get the brake plate out without having to remove it from the torque arm, if you're careful, and avoid having to put a new split-pin through the bolt, if it uses one. Thumbs Up
PostPosted: 20:15 - 10 Jun 2011    Post subject: Reply with quote
If it's a disc rear brake, something to push the pistons back in with (either levering them against the back of a pad or wind them in with a g-clamp).
EDIT: And a pair of latex gloves because you'll be messing with the chain.
AHurdwell
PostPosted: 23:15 - 10 Jun 2011    Post subject: Reply with quote
Thanks for all the help guys, think I will just take it off at home and see if the gf will drive me down there....
The last post was made 15 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 43.02 Kb
