ABS fitted retrospectively?
charlie_a
PostPosted: 13:57 - 10 Jun 2011    Post subject: ABS fitted retrospectively? Reply with quote
Looking into trading in my Alp for a similar big trailie. There's a nice nearly new Tiger 1050 going on Autotrader that doesn't have ABS.
Would you recommend getting this fitted retrospectively and is it even possible?
I see Triumph quote £550 to add ABS to a new non-SE version on their configurator site.
Thanks
PostPosted: 14:13 - 10 Jun 2011    Post subject: Reply with quote
I would doubt is can be retrospectively fitted, at least not without spending a hell of a lot.
My guess would be that you would need replacement wheels (or maybe just disks) to trigger the sensors, different wiring loom, ABS pumps and lines. Different clocks and master cylinders also wouldn't surprise me (although I suspect they are the same).
PostPosted: 14:13 - 10 Jun 2011    Post subject: Re: ABS fitted retrospectively? Reply with quote
Thanks
It would cost a fortune I would hazard a guess at £1000-1500
Just found a list of all components required and the cost
1: PULSAR RING,FRONT,ABS
1389637
(5568073-001) $249.58
2: BOLT, HHF, M5 X 12, ENCAP
1397842
(5576299-001) $3.69
3: SENSOR,WHEEL SPEED,ABS,FRONT
1796840
(6179117-001) $143.19
4: CLIP,LEAD,SENSOR,ABS
1796821
(6179098-001) $9.90
5: BOLT, RHHF, M6 X 16, ENCAP
1397664
(5576121-001) $3.15
6: FRONT BRAKE HOSE ASSY ABS
1796833
(6179110-001) $74.20
7: FRONT,ABS FEED, PIPE
1796838
(6179115-001) $77.29
8: FRONT, ABS RETURN,PIPE
1796839
(6179116-001) $79.29
9: CLIP, TWIN, D8.0
2533695
(7717836-001) $2.41
10: HEX HD, ENCPSULATED M4X25
1568827
(7717690-001) $2.32
11: ABS MODULATOR ASSY, WET
1796831
(6179108-001) $1,538.60
12: BRACKET, ABS MODULATOR
1796832
(6179109-001) $39.27
13: MOUNT, RUBBER, ABS UNIT
1389668
(5568104-001) $5.55
14: SCREW, TORX M6 X 25
1568825
(6178659-001) $2.18
15: FLANGED SLEEVE
1380415
(7534900-001) $3.75
16: PIPE,ABS,FEED,REAR
1796836
(6179113-001) $63.40
17: PIPE,ABS, RETURN, REAR
1796837
(6179114-001) $62.61
18: REAR ABS FLEXIBLE
2125414
(6625907-001) $81.49
19: P CLIP, ID 8, STEEL
1568889
(5967771-001) $3.37
20: SPEED SENSOR, ABS, REAR
1796841
(6179118-001) $125.72
21: BOLT,HHF,M6X1X12,BLK
1797598
(6179898-001) $2.19
22: HOSE GUIDE
2126331
(6626849-001) $9.80
23: SHIM, ABS SENSOR, 1.0MM
1389718
(5568154-001) $3.67
23: SHIM, ABS SENSOR, 0.5MM
1389717
(5568153-001) $3.67
24: SCREW, TORX, PAN HD, M5X0.8X16
2811212
(6179904-001) $0.81
PostPosted: 14:14 - 10 Jun 2011    Post subject: Reply with quote
And a lot of those parts you will require more than 1.
charlie_a
PostPosted: 14:17 - 10 Jun 2011    Post subject: Reply with quote
Shame, was really nice bike.
Cheers!
DrDonnyBrago
PostPosted: 14:22 - 10 Jun 2011    Post subject: Reply with quote
Why do you feel that you need ABS?
Contrary to what BMW would like you to think, ABS is not required to ride safely.
PostPosted: 14:32 - 10 Jun 2011    Post subject: Reply with quote
NEIN! ZIS IS UNPOSSIBLE! ALL PANZERZWEIRADMASCHINE MUST HAF ZE ABS BRAKES. ZIS VILL BE ZE LAW IN ZWEITAUSENDSIEBZEHN (2017) ACROSS "EUROPE" OR GROß-DEUTSCHLAND AS IT VILL BE KNOWN BY ZEN!
charlie_a
PostPosted: 14:34 - 10 Jun 2011    Post subject: Reply with quote
Going on my experience with the Transalp riding around London for the past 3 years. It's saved me locking up the front wheel a few times - when someone stepped out without looking or a car stopped for no apparent reason.
Could always ride more defensively or work on not locking-up the front but good to have a safety net when the first two fail.
The last post was made 14 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 59.37 Kb
