Custom clutch springs...
SpannerMonkey
PostPosted: 21:46 - 10 Jun 2011    Post subject: Custom clutch springs... Reply with quote
The clutch springs on my PC50 are giving way, Anything even SLIGHTLY above idle nudges on the back wheel leaving me with no usable torque for pulling off... Honda dont stock the springs as a spare part... Can anyone recommend somewhere where I can get hold of custom springs? I'm after a service where I can send them my springs and say what I'm after... and they do the technical stuff and hand me shiny new miracle springs to use...
Anyone know anywhere?
My bike? A YX140 powered one-off Monkey Bike, something a little different!
MickC
PostPosted: 22:02 - 10 Jun 2011    Post subject: Reply with quote
Not sure on that mate but there is this on ebay
https://cgi.ebay.co.uk/Honda-PC-50-Engine-/280690328143?pt=UK_Motorcycle_Parts&hash=item415a72824f
Might be worth getting it an seeing if there are any usable bits on it
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
SpannerMonkey
PostPosted: 22:04 - 10 Jun 2011    Post subject: Reply with quote
Naaa, No point going second hand, it's like a step backwards... I want this bike to get BETTER... not equal or worse...
ThoughtContro...
PostPosted: 22:15 - 10 Jun 2011    Post subject: Reply with quote
What number and size of springs do they have to be? I've got 4 CBR125 clutch springs out the back doing nothing, that you could have for nowt of they're any use.
Prize cunt
SpannerMonkey
PostPosted: 22:18 - 10 Jun 2011    Post subject: Reply with quote
Not 100% sure yet, Will be taking a look tomorrow Smile
ThoughtContro...
PostPosted: 22:40 - 10 Jun 2011    Post subject: Reply with quote
They're 19.1mm diameter an 38.6mm long
Prize cunt
ThoughtContro...
PostPosted: 13:40 - 11 Jun 2011    Post subject: Reply with quote
Vincent wrote:
Springs have a specific "tollerance" in length. Once the spring measures less than the limit, it's time to replace. You need to find out what the tollerance is, (usualy in the workshop manual), and measure yours.
And if it's a Haynes manual hope it gives you the right value.
I changed the springs on my CBR125 for some EBC ones when I was checking the clutch plates, bearings etc. The springs were shorter than the stated tolerance. No big deal. Got the new springs from wemoto and they're shorter than the Haynes stated minimum value too. So I probably changed them for nothing, hence why they didn't get thrown out.
Prize cunt
SpannerMonkey
PostPosted: 15:15 - 11 Jun 2011    Post subject: Reply with quote
Being a haynes manual from the 70's it doesnt go into that much detail, heck, and 70s tech applies, for example, 'the output from the flywheel generator can be checked only with specialised test equipment of the multimeter type, it is highly unlikely the average owner/rider will have acess to this equipment' hmmm... It also says 'honda do not supply any clutch centre parts stating that the assembly must be matched and set to operate at the correct speeds, thereforea complete assembly must be baught if any faults are found'
SpannerMonkey
PostPosted: 15:20 - 11 Jun 2011    Post subject: Reply with quote
I just twigged on, you guys think im on about a plate clutch! Its a centrifugal unit. Like a scooter =P hence the need for custom ones.
Teflon-Mike
tl;dr
PostPosted: 15:34 - 11 Jun 2011    Post subject: Reply with quote
And being a centrifugal clutch, the problem is as likely to be the clitch slippers as much as the springs.
Think about that Haynces comment about the masses being balences so it flies out to grip at the right rpm.... actual slippers are like a brake shoe, as they wear through slip, they loose mass, right? Also the clerance between slipper face and drum increases.
and little bikes with centrifugal clutches, slip a LOT.
Though in your case forty year old example, the springs, having been left in tension for umpety years, will have relaxed.
I'd pull it, do some measuring, and be asking pertinent questions of the purveyors of pit-bike or mini-moto bits, personally, for some slippers and new springs.
You can get springs custom would, but you are talking a lot of money. British Springs (Redditch, I think) make a lot of automotiove springs, and do a lot of the suspension 'kit' springs, for the catalogue people... but pretty sure they have a full catalogue for automotive & industrial applications.
If not..... down to measuring the length and rate of the springs you have... length you can do with a ruler, (as diameter) rate, like in GCSE Science... hang one on a nail, then hang a pop bottle on the end with a bit of string, add water to pop bottle at the rate of 1Kg or 9.81N per litre, and measure how many mm of stretch you get per N or cc of water....
Add 'a bit' to the rate for relaxing, take a bit off teh length for stretch.... then google springs, and see what catalogues you find, and what in them has similar specs..... buy & try.
The last post was made 15 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 75.02 Kb
