Starting problem Piaggio 50cc NRG mc3 LC
humphreys-j1
PostPosted: 20:13 - 11 Jun 2011    Post subject: Starting problem Piaggio 50cc NRG mc3 LC Reply with quote
Hi, my piagio 50cc will only start when cold if the throttle is wound wide open and the starter engaged for about 30seconds for 2 or 3 times. Auto choke ok, Auto petrol tap new, jetted up to 72 and needle altered 1 notch, new race can fitted, please help before starter wears out.
GREENI3
PostPosted: 20:46 - 11 Jun 2011    Post subject: Reply with quote
I assume you've tried to kick start it?
humphreys-j1
PostPosted: 21:04 - 11 Jun 2011    Post subject: Piaggio 50cc won't start Reply with quote
Yes until leg gets cramp.
Nope.
PostPosted: 21:08 - 11 Jun 2011    Post subject: Reply with quote
A 72 jet sounds far too high. Are you sure your not flooding it?
Do a plug chop. It could be that its running far too rich or it could just be that your plug's fowled. Look at it and change it. See if it makes a difference.
Gamble
PostPosted: 21:11 - 11 Jun 2011    Post subject: Reply with quote
As computid says 72 sounds like a far too large jet size as I believe these run a 56 standard? If it's only running the exhaust you only need to increase around 10%.
Nope.
PostPosted: 21:15 - 11 Jun 2011    Post subject: Reply with quote
This ^^^^
My freind has a piaggio NRG with a 70 kit and a sports pipe and hes running a 72 jet which is slightly rich for him!
You need too sort your jetting out first really!
humphreys-j1
PostPosted: 22:13 - 11 Jun 2011    Post subject: Reply with quote
Cheers for that, I will change jetting, would I have to put the needle back to original position. Where can I get a single 62 or slightly higher jet from, I don't really want to buy a jet pack with loads of jets.
Gamble
PostPosted: 00:52 - 12 Jun 2011    Post subject: Reply with quote
Yes change it back and if it doesn't feel right, put it back as it is now. Or in reverse, unfortunately it's trial and error.
The last post was made 15 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 54.24 Kb
