Battery charging and rear shock
Chris750
PostPosted: 14:10 - 12 Jun 2011    Post subject: Battery charging and rear shock Reply with quote
I have some queries if anyone can help me. These questions may seem stupid to some but I'm just not sure so here goes
Firstly:
I have bought a battery charger for my car/bike. The instructions on the charger (to charge the batttery) are to connect the +ve terminal to the battery then the -ve terminal to the vehicle chassis.
When I do this the charge light doesn't come on.
However when I connect the battery to both terminals in order to start the bike direct from the charger, the charge light comes and it gives the battery charge.
Now is it ok just to charge the battery by connecting to both terminals, I have never heard of having one of the terminal connected to the chassis before?
Incidentally when the instructions tell you to connect the -ve termial to the chassis the picure appears to show it being connected to the battery.
Secondly:
The rear shock is connected by a tube to a metal cylinder fixed to the frame under the rear seat. What is this called (and whats its function)?
Thanks
Chris
Current Rides: GSXR-750 WS, GSXR-1000 K5, KTM EXC 300
iooi
PostPosted: 14:22 - 12 Jun 2011    Post subject: Reply with quote
When you connect the charger to the chassis, do you still have the -ve wire connected to the battery ?
Personally I take the battery out when charging and simply use the terminals on the battery.
Helps to keep things cool.
Chris750
PostPosted: 16:53 - 12 Jun 2011    Post subject: Reply with quote
Yes I still have both terminal attatched, I think I will take battery out also and try that
CaNsA
PostPosted: 17:03 - 12 Jun 2011    Post subject: Reply with quote
there does have to be a clean metal surface for the electricity to pass from the terminal to the frame.
Serendipity
PostPosted: 18:09 - 12 Jun 2011    Post subject: Re: Battery charging and rear shock Reply with quote
Sounds like a remote reservoir. Used to keep the damping oil in the shock from overheating under extreme conditions...
...I think. At least that's what I had on my CBR before I wore it out and replaced it with a Hagon.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
The last post was made 15 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 48.23 Kb
