bulk cleaning nuts and bolts
PostPosted: 09:51 - 13 Jun 2011    Post subject: bulk cleaning nuts and bolts Reply with quote
Right the TDM is in the middle of an almighty clean/repair/Strip down. I have loads of bolts etc. that I want spruced up what is the best way to do this I was thinking ultra sonic cleaner any better ideas? The bolts have lots of both dirt and corrosion on them.
MarkJ
PostPosted: 10:01 - 13 Jun 2011    Post subject: Reply with quote
Vinegar will remove the rust, but leaves them looking quite dull Thumbs Up
DrDonnyBrago
PostPosted: 10:33 - 13 Jun 2011    Post subject: Reply with quote
If they have rusted then they will rust again as soon as you clean them up. I'd leave them in a jar of paraffin for a while to loosen the muck so you can assess how bad they are (corrosion).
If they are badly corroded then I'd replace them with stainless (non structural) or zinc coated high tensile steel for structural bolts/nuts.
If you have an ultrasonioc cleaner already then use with some cheapest of the cheap cola in it to clean them, they will still corrode afterwards if they are rusty but it should remove it. Soaking in vinegar loosens off rust but again, but as with everything else it wont be protected by anything afterwards.
If you have loads to do and they are pricey to replace, you can get them zinc plated (as they were to begin with), no idea on costs/locality mind but it may be worth considering.
PostPosted: 12:18 - 13 Jun 2011    Post subject: Reply with quote
None are rusty just slightly skanky dull with white spots etc. I've just bought an Ultra sonic cleaner so will give it a go. Thumbs Up
The last post was made 15 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 39.63 Kb
