| Willson |
 Willson Traffic Copper
 Posted: 18:33 - 12 Jun 2011 Post subject: HOW TO: Remove a seized bolt |
For those that don't know.
Seized bolts are obviously a pain in the arse, and unless you do it right, can result in lots of rounded heads, knackered tools, painful fingers and lots of swearing (I know this from experience).
First thing I tend to do is spray on a healthy amount of Plusgas:
https://www.c1store.co.uk/store/images/plusgas1.jpg
And try a bit more leverage.
Try to tighten it a little first just to loosen it up (Thanks CaNsA, I missed this bit), then try to undo it.
With allen keys/socket wrench I tend to find slipping a cheap ring spanner around the end of the tool and using that as a lever tends to help as well.
Dependant upon what you have to hand and where the bolt is, you could try using an impact driver. If trying to undo it doesn't work straight away with this, go back and forth etc. (Had this problem with a seized front sprocket nut, and the above still didn't loosen it). I originally forgot about this step as I don't have an impact driver. Thanks Joe for pointing this out
If you're still having no luck, then heat the area of the bolt with a blowtorch. Obviously if you're working with any bolts that are too close to flammable fluids this presents it's own set of hazards such as blowing yourself up. So I take no responsibility for anyone stupid enough to try that.
After heating up said bolt (not just the head, down where the shaft of the bolt would be if you can) try again with the wrench and spanner combination and it should come right out.
If at the end of this you're still in the same problem as before it's time to take it to a professional. I used the above method for removing the gear change from my SV650s earlier on as it had been put together with thread lock and the allen key kept slipping out and it worked just fine. So if I can do it, anyone can!
I'll get some pics taken of the above steps and update this later on/tomorrow/in the week.
Willson ____________________ Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
| CaNsA |
 CaNsA Super Spammer
 ..... Quote Me Happy
| Willson |
| CaNsA |
 CaNsA Super Spammer
 Posted: 18:57 - 12 Jun 2011 Post subject: |
LOL Wilson,
bloody half-arsed effort there......
| Willson |
 Posted: 19:00 - 12 Jun 2011 Post subject: |
I was going from what I've done this afternoon... let me have my moment! Updated just for you!
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold |
| CaNsA |
 CaNsA Super Spammer
| Willson |
 Posted: 19:05 - 12 Jun 2011 Post subject: |
When I do the pics I'll try and get my missus to pose then
And what you mean? Try to tighten the bolt before undoing it?
| BigGeeking |
 BigGeeking Scooby Slapper
 Posted: 19:16 - 12 Jun 2011 Post subject: |
thanks mate good help  |
| CaNsA |
 CaNsA Super Spammer
| Willson |
| DrDonnyBrago |
| AndyB1989 |
 AndyB1989 Scooby Slapper
| G |
 G The Voice of Reason
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:09 - 13 Jun 2011 Post subject: |
A sharp tap on the head (directly in the direction of the shaft) can also break it free.
I haven't tried Wall Drive (but shall order some forth-with ) but Irwin Bolt Grips are the daddy for bolts / nuts that are starting to round off, where you just want to get them off rather than preserve the head. They're sockets with a twist that bites down on the head as you turn.
If you've got room, a pipe wrench will also bite down on a rounded head. ____________________ Biking is 1/20th as dangerous as horse riding.
| The Artist |
 The Artist Super Spammer
| Willson |
| Lipsmoker |
 Lipsmoker Trackday Trickster
 Posted: 19:18 - 13 Jun 2011 Post subject: |
Yeah the method of tightening it has always worked for me,
A seized bold 99% of the time is rust in the threads so the tightening and loosening method helps work the rust to the end of the thread. You can undo pretty much anything with patience, not everyone has impact tools to hand.
Rogerborg some good tips there  ____________________ Four wheels move the body. Two wheels move the soul. |
| pepperami |
 pepperami Super Spammer
 Posted: 19:26 - 13 Jun 2011 Post subject: |
I`ve found that if you`re careful and not over zealous, repeated heating and rapid cooling can get a nut/stud/bolt to let go.
I recomend that you throw away the nut/stud/bolt afterwards though, because you`ll possibly find the process has changed the make up of the metal (weakened it)
worked for me on a old exhaust stud that refused to let go  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| trisers |
 trisers Scooby Slapper
 Posted: 23:10 - 13 Jun 2011 Post subject: |
The best one with a rounded off bolt head or a stuck stud is to weld a big nut to the top of it.
As well as giving you something to unscrew, the phenomenal quantity of heat this bungs into it in such a localised manner is pretty much impossable to achieve any other way. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Aivaras55 |
 Aivaras55 Borekit Bruiser
| sandman1976 |
 sandman1976 Nova Slayer
 Posted: 19:49 - 16 Jun 2011 Post subject: |
Also....
This morning i got a bolt stuck in, with an allen key head, and of course the allen fitting stripped before the key!
Welder out, welded a 10mm nut to the head of the bolt (welding on the inside of the nut)
Hey presto, cracked it off with a 10mm spanner  |
The last post was made 14 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
