GPZ500 barend fitting?
MikeyBrown
PostPosted: 18:43 - 13 Jun 2011    Post subject: GPZ500 barend fitting? Reply with quote
On my gpz I would like to fit a pair of barends, just to tidy up the end of the grips to be honest.
However, I have come to fit them and noticed that there is a plate/tube of steel welded into the end of the bars. How would I go about removing this and what is it for? (the steel is thick and the weld is very good)
Also, if I cannot remove it, how would I go about fitting barends into my bars?
Many thanks,
Mike
Past Bikes: '97 CG125, '91 GPZ500S, '01 FZS600, '07 S/Triple, '99 ZX9R, '82 GP125, '83 GP100, '03 SV1000S, '98 ZX6R
Current Bike: '07 FZ1N
Trackdays: Darley Moor - 15/6/12, Donington - 28/8/12
Nexus Icon
PostPosted: 18:49 - 13 Jun 2011    Post subject: Reply with quote
It sounds like they're pre-weighted. If the bar-ends you have bought are purely for cosmetic reasons then there are a few ways you could make them fit. If you're just not happy with the bars on there then a set of renthals is only £25.
Greetings from Shitsville!
MikeyBrown
PostPosted: 18:51 - 13 Jun 2011    Post subject: Reply with quote
Do you have any ideas how I might be able to install them? As I can't fit renthals because my bars are clip-on style :/
PostPosted: 19:02 - 13 Jun 2011    Post subject: Reply with quote
Depends on how the bar ends you have bought attach.
You will probably need to chop away the end of the grips (if the original ones), then drill out the end of the bars.
If you want normal bars then I suspect you can buy adapters that bolt on instead of the "clip ons". LSL used to make them but don't know if they still do.
MikeyBrown
PostPosted: 19:17 - 13 Jun 2011    Post subject: Reply with quote
Thanks, the bar-ends I have attach like these ones; https://images.esellerpro.com/2319/I/928/50/BE-101.jpg
And I don't have the original grips on, so there is no end to the grips so they don't need cutting. But I don't fancy swapping the bars as I like the originals.
Do you now how thick/long the welded in bit would be? So far I've drilled about 1/2 inch and I'm getting nowhere near through it Sad
Nexus Icon
PostPosted: 19:39 - 13 Jun 2011    Post subject: Reply with quote
Personally, I'd have cut off the external piece of the bar end and just drilled and tapped into the solid piece inside the bar to take the Allen bolt.
That's if it was just a cosmetic thing.
The only way to fit them properly is to keep drilling as you are, to a depth that will accept the bar ends.
whitedevil
PostPosted: 20:57 - 13 Jun 2011    Post subject: Reply with quote
You have 2 options
1: drill out the bar ends to fit the size of the bolt used with your bar-ends then use a tap and die set to cut a thread into the drilled out end.
2: Buy some 2nd gen (1994-) clip-ons, which have the fittings already in the ends.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
PostPosted: 21:10 - 13 Jun 2011    Post subject: Reply with quote
Think you will have to drill away. However doing this you are removing the weight of the steel and replacing it with the light alloy bar end.
MikeyBrown
PostPosted: 22:30 - 13 Jun 2011    Post subject: Reply with quote
In all honesty then, I'm tempted to just make up a bmx plastic barend and see if I can make that fit without drilling it out.
I might have to play a little bit of 'captain bodge-it', but it should tidy up the ends of my grips Wink I hope...
PostPosted: 22:56 - 13 Jun 2011    Post subject: Reply with quote
Or just buy some original style grip which cover the ends of the bars.
MikeyBrown
PostPosted: 23:37 - 14 Jun 2011    Post subject: Reply with quote
Ahhhhh yes, I never thought of that :$ silly me ahaha I'll go shopping tomorrow...it gives me an excuse to spend money Wink
Thanks again Keith Very Happy
The last post was made 15 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 71.17 Kb
