| clemsta |
 clemsta Scooby Slapper
| Git |
 Git Brolly Dolly
| mr jamez |
 mr jamez World Chat Champion
 Posted: 19:21 - 23 Aug 2004 Post subject: |
Probably if you are really giving it some abuse for an extended amount of time, though it should be ok as it has oil cooling it and being a 125 probably doesn't stress the clutch much. Obviously if you are always doing this then it will wear out quicker, but a clutch kit only costs about £30 so who cares  |
| Guest |
 Guest Brolly Dolly
 Posted: 20:20 - 23 Aug 2004 Post subject: |
Imagine the palm of your left hand is a steel clutch plate, and the palm of your right hand is a fibre one.
Now rub them together very quickly.
Notice anything?
 Posted: 21:26 - 23 Aug 2004 Post subject: |
Yes. They tend to get hot with a lot of that, seems to make the lever come closer and closer to the bars before it disengages. If this starts to happen either stop and allow to cool down or go for a ride up and down the road as normal for a bit to allow it to cool down.
My Russian 2-stroke actually had SMOKE coming out the crankcase breather after a lengthy U-turn session when I was learning. Only holds a pint and a half of gearbox oil so not much wonder! ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| clemsta |
 Posted: 21:53 - 23 Aug 2004 Post subject: |
Yeah mine had a little poof of smoke after doing a donut, and it was slipping badly, i just stopped for 5 minutes and had a breather, then it was fine again. I checked the gearbox oil but it is correct. I'll just have to take it a bit easier next time.  |
The last post was made 21 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
