RC valve
Finney2003uk
PostPosted: 23:28 - 23 Aug 2004    Post subject: RC valve Reply with quote
also anouther question u no the RC valve on the nsr 125 f s should it be up or down if u no what i mean unscrewed or screwed which way opens it and does it make a diffrance if up or down
alains
PostPosted: 00:10 - 24 Aug 2004    Post subject: rc valves Reply with quote
the valves are piloted by a servo-motor which is controled through the cdi box . look on your right side , you can see the cables . start your engine , then put up revs and you will see the pulley turning anticlockwise for openning the valves .
i join you a copy of how it works
Finney2003uk
PostPosted: 00:21 - 24 Aug 2004    Post subject: Reply with quote
so how do i turn it up so it will make me bike faster lol tight or unscrew the lead which go in to the rc valve or some thing else
alains
PostPosted: 00:40 - 24 Aug 2004    Post subject: speed Reply with quote
this is because your valves do not open fully and also because a poor compression (6,8:1) , rough surface transfers and not enough volume of mixture . to do a better openning of the valves it's a very simple thing to do : take off the screw in the middle of the pulley (on right of the tank) . lift up gently the pulley . pull the right cable of its stop (do not pull out completly) . take a piece of aluminium paper and turn a bit around the cable and refit the cable by pushing it firmly . take it of again and verify if the thickness is at least 1 mm and max 2 mm. this make the cable pulling more .
that's all .
i recommand that you read the topic RC valves control , put yesterday and tell me if you will be interessed . finally if you want to know how to boost it , ask me .
Finney2003uk
PostPosted: 00:50 - 24 Aug 2004    Post subject: Reply with quote
how well does it improve the proformance if its good i will be very intrested would 10 uk pounds be ok 4 it
The last post was made 21 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 42.8 Kb
