| ShingH |
 ShingH L Plate Warrior
| Finglonga |
 Finglonga World Chat Champion
| ShingH |
| mr jamez |
 mr jamez World Chat Champion
| ShingH |
| mr jamez |
| Claud 14.7 to 1 |
 Claud 14.7 to 1 World Chat Champion
 Posted: 21:58 - 23 Aug 2004 Post subject: |
What a situation.
Drain all the 2 stroke oil out asap, put fresh 4 stroke oil in. Run it for a few minutes. Hopfully it will work, and be fine.
Then get some engine flush. Follow the instructions labled. Use it with the new oil.
After using the engine flush, completely drain the oil again, and put another quantity of new oil in.
Hopefully the engine flush (coupled with the 2 oil changes) will get as much 2stoke out as possible. And help dilute any remaining oil, should there be any traces left. The more times you change the oil, the cleaner your engine will be (so you could even do a third change it you really wanted to). The engine flush will help to clean out all the bits of crap in the engine (including the 2 stroke oil).
The plugs may be cacked up, so it would be wise to check/clean/replace them.
And hopefully it will be ok.
Good luck
| Claud 14.7 to 1 |
 Posted: 21:59 - 23 Aug 2004 Post subject: |
Oh and change the oil filter as well with each oil change. Both times (both oil changes) to be on the safe side.
Hopefuly any traces of 2 stroke in the combustion chanber should be burnt off harmlessly. Its just the wear damage to the engine that could have occured, that is the problem, due to the fact that it was completely the wrong oil.
Ps. My old Nissan Micra regularly runs with oil warning light on, and it still pulls well. So dont loose all hope. And i kain it, lol  |
| Kickstart |
 Kickstart The Oracle
| stinkwheel |
 Posted: 22:21 - 23 Aug 2004 Post subject: |
You should be OK if it was just a fairly small amount. Two stroke oil will still lubricate the major engine componants like the bearings and bores. Not so good in a gearbox and wet clutch though, the gearbox would take rather longer to suffer damage.
I would do the same as kickstart. Drop the oil out, change the filter and refill with proper engine oil. Run it for a few miles then repeat the change.
I'd just stick something like ordinary Castrol GTX (not magnatech) in a GS450 so not too expensive. Flushing oil shouldn't really be necessary (and cheap-ass oil will do the same job).
GET a workshop manual (Haynes or Clymer), there are pictures and everything! ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Finglonga |
| Guest |
 Guest Brolly Dolly
 Posted: 23:30 - 23 Aug 2004 Post subject: |
As Keith and Stinky - change oil and filter now, run it for a few miles till it's nice and warm and then change oil and filter again. I wouldn't be fussed with flushing it. A little 2T still in won't hurt, those old GS's are tough old birds - ball bearing cranks will run on water
I wouldn't bother using anything fancy in it either, basic 10/40 was all there was when it was new and it'll be good enough for it now.
If the previous owner was running it on choke for 10 minutes I'm not surprised the plugs are fouled - stick some new ones in. I'd guess after all this time it could do with a carb strip to check jets. needles, float heights etc. |
| ShingH |
| Ste |
 Ste Not Work Safe
 Posted: 02:43 - 24 Aug 2004 Post subject: |
Take it to a different shop, I wouldn't trust that shop further than I could throw it.
You should be able to get to the sump plug to drain the oil without moving the exhaust, but if needed you can undo it, move it out the way then put it back on, just unbolt it from the front of the engine and the can and then you're fine. Before you put the two stroke oil in was it running okay yeah? Should run even with the two stroke oil in (don't though!) drain the old oil and change the filter as said, then flush it round with good oil to get all the rest of it out then do another oil and filter change as said up there.
Out of interest where are you in the country as there might be someone not far away who would be able to help you.  |
| ShingH |
 Posted: 16:41 - 24 Aug 2004 Post subject: Um... |
As for where in the country... I don't think I *am* in the country... over here in the U.S. - dunno how I ended up finding the board, just googled a few motorcycle terms and here I am!
Don't think the shop I went to is representative of most over here - and I didn't bring the bike in, since it wasn't running even before I did the oil change (spark plug problem I think, as before)... I'd just gone in and asked, and the guy for WHATEVER reason just assumed I could only be riding some lawnmower of a 50cc bike or something... ignorant jerk  |
| Rory |
 Rory Traffic Copper
 Posted: 20:22 - 25 Aug 2004 Post subject: |
I know they don't cost much, but is changing the filter more than once really going to make any difference? Surely it's there to filter out dirt particules that aren't dissolved in the oil? Or would the two-stoke oil possibly dislodge other crud in the engine? Just thinking out loud... ____________________ My Old CBR400RR | Bike Oil FAQ | Petrol FAQ |
| ShingH |
| Kickstart |
| ZRX61 |
 ZRX61 Victor Meldrew
| stinkwheel |
| Rory |
 Rory Traffic Copper
The last post was made 21 years, 307 days ago. Instead of replying here, would creating a new thread be more useful? |
