CG125 brazil, CLUTCH!
taz408
PostPosted: 15:57 - 19 Jun 2011    Post subject: CG125 brazil, CLUTCH! Reply with quote
Hello all - MY BIKE IS BROKEN Crying or Very sad
The clutch simply doesnt work... You shift from neutral to 1st (with the clutch pulled in of course - the wheel starts to spin... you rev more with clutch PULLED IN - the wheel goes faster...)
Where and what do you think I need to do? Smile
PostPosted: 15:59 - 19 Jun 2011    Post subject: Reply with quote
It's just dragging. You need to adjust the clutch cable at the lever, or the engine end.
taz408
PostPosted: 16:09 - 19 Jun 2011    Post subject: Reply with quote
Okay, so I have dabbled with the screwy bit near the handle for the clutch. Doesnt make a blind bit of difference, unfortunately the nuts near where the clutch cable joins into the engine, cant be moved. When i twist the nut - the cable twists, and I physically cant work out how to keep the cable casing still, whilst i twist the nut... Any ideas?
BigGeeking
PostPosted: 11:04 - 20 Jun 2011    Post subject: Reply with quote
yeah where the cable passes through the bracket next to the leaver on clutch casing there is a small flat on the end of the cable next to the 2 nuts think its about 8 /6 mm.
or just use grips to stop it spinning Thumbs Up
nighthawk250
PostPosted: 13:01 - 20 Jun 2011    Post subject: Reply with quote
Do you have any 'free pay' on the cable?
taz408
PostPosted: 14:37 - 20 Jun 2011    Post subject: Reply with quote
Umm, Sorry my mechanical expertise is ZERO. Could you explain what you mean?
If you mean, is it at all slack? No, i's not. Smile Cheers for the replies guys
PostPosted: 14:54 - 20 Jun 2011    Post subject: Reply with quote
Hang on, is it doing this while up on the centre stand?
Do you actually have problems with it on the road? When you put it into 1st gear with the clutch pulled in, does it jump, stall, or start to creep forwards?
If not, if it's only doing it while up on the stand, then try (carefully) putting your hand on the rear wheel with the clutch pulled in. Can you stop it with your hand?
If so, then it's not a problem. Your bike has a wet clutch. There's oil in there, and even with the clutch plates fully disengaged there's some viscous coupling that will turn the output shaft and the rear wheel. This looks surprising and wrong the first time you see it, but it's normal for wet clutches.
taz408
PostPosted: 15:38 - 20 Jun 2011    Post subject: Reply with quote
Hmmm, well it's on the centre stand, but it's quite hard to stop it with my hand. Unlike my dads who definately has what you are describing as a wet clutch. The power being put into the wheel is a fair bit more for this bike...
nighthawk250
PostPosted: 17:06 - 20 Jun 2011    Post subject: Reply with quote
A cable consists of an inner and an outer part, the black outer is fixed at the ends and does not move.
The inner stranded core moves.
Free play is needed on all clutch cables, and is easily measured by feeling for slack on the lever or pulling at the ends of the outer cable. At the clutch lever you should have 5mm of gap (free play), when the lever is not in use.
taz408
PostPosted: 17:35 - 20 Jun 2011    Post subject: Reply with quote
So when it's not in use, I should be able to move it side to side, by 5 mm yeh? Like testing for a slack chain? Smile thanks for all your help so far Smile
The last post was made 15 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 62.92 Kb
