Painting luggage plastics
flumpy7
PostPosted: 17:45 - 19 Jun 2011    Post subject: Painting luggage plastics Reply with quote
Hi guys
Heres a question for those that can paint.
Gonna spray my vfr800 panniers from black to red to match my bike. Now, there is no damage to the panniers so my question is how do i prep the surfaces. Will it be sufficient to just rough them down, prime, sand, prime, sand, paint etc.... or will i need to rub all previous paintwork off? That would seem a bit overkill to me but want it to look pretty decent so will if i have to.
Also, as far as i know the italian red is non-metallic and was wondering what people find best for the top coats. i.e. rub down with wet and dry before lacquer or after.
Cheers
2012 Sinnis apache
AndyB1989
PostPosted: 23:05 - 19 Jun 2011    Post subject: Reply with quote
all the effort shoudl be spent on the prep.
the original paint you say is damaged i would remove as much as is loose from around the damaged areas and then fether the edges and build up the now bare patches with a hi build primer (make sure its a plastic primer) two coats of primer and then sand with some very fine wet and dry if you go through it on the edges you need another coat and once the primer is on and very flat and smooth blast it with topcoat after the topcoat assuming no runs or other blemishes several coats of laquer then cut back and polish (after its hardened )
hmmmnz
PostPosted: 23:25 - 19 Jun 2011    Post subject: Reply with quote
just take the gloss off,
if you hit bare plastic, you'll have to prime as well,
normal paint goes all crazy when it hits plastic,
the humans are dead
I kick arse for the lord
flumpy7
PostPosted: 10:34 - 21 Jun 2011    Post subject: Reply with quote
Cheers guys.
There is no damage, but think i will prime anyway to be on the safe side. Cheers andy for the advice re topcoats and lacquer, just waht i needed to know.
2012 Sinnis apache
The last post was made 15 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 39.95 Kb
