yamaha aerox 08 wont run right
Philoates27
PostPosted: 19:03 - 20 Jun 2011    Post subject: yamaha aerox 08 wont run right Reply with quote
My yamaha aerox starts and idles but then will die when trying to apply throttle, i have cleaned the carb and air filter out but still wont run any ideas?
Blob
PostPosted: 19:07 - 20 Jun 2011    Post subject: Reply with quote
Whats the idle speed like? If it's too fast, a tad throttle can cut off the engine. Check it out Thumbs Up Had this issue with a friends bike and was the idle speed all along, may not be the same in your case but it's worth a butchers.
-Will
Philoates27
PostPosted: 12:30 - 21 Jun 2011    Post subject: ? Reply with quote
have tryed playing around with all the throttle adjusters and still nothing, any more ideas
Blob
PostPosted: 12:52 - 21 Jun 2011    Post subject: Reply with quote
Have you tried resetting/altering the air mixture? Also have you checked out your fuel tank vent or fuel tap?
-Will
Philoates27
PostPosted: 16:20 - 21 Jun 2011    Post subject: Reply with quote
it dosent have a fuel tap but i did phone webbs early and they said check the fuel tank iam guessing they mean the filter inside to see if its all dirty ?
Blob
PostPosted: 19:37 - 21 Jun 2011    Post subject: Reply with quote
Check the filter and maybe reset your air mixture screw (if you have one) this may have loosened causing too much or too little air in.
Philoates27
PostPosted: 10:59 - 22 Jun 2011    Post subject: Reply with quote
cheers for all the help so far but i have tryed it all and still nothing do you think it could be anything to do with the rollers?
Blob
PostPosted: 11:21 - 22 Jun 2011    Post subject: Reply with quote
Have a look at your jets, rollers and spark. Also check your manual about how many turns your air mixture should be on and if it's not stated call Yamaha and ask, if checked you MAY have it screwed on too loose/tight.
Post a picture of your spark, it may be worn
The last post was made 14 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 53.61 Kb
