| ajc219 |
 ajc219 L Plate Warrior
 Posted: 14:49 - 14 Jun 2011 Post subject: Suzi GN125 fuelling/idle problems |
Hello, first post here. Just doing my DAS, passed Mod 1 and now running around on a 125 to keep my hand in 'til a second attempt at Mod 2 in July - failed last week for a distinct lack of lifesavers
The 125 in question is an 11 year old Suzuki GN125, 500 miles on the clock and £100. It has spent most of it's life sitting in a shed, so is in pretty good nick (passed MoT no issues) apart from the tank and carb as it was put-away with petrol in the tank...
I've de-rusted and Jenolited the tank, new fuel filter and all is fine there. The carb, a Mikuni CV, was pretty gunked-up so I stripped it and cleaned everything in an ultrasonic bath and then with compressed air. Carb is rebuilt and back on the engine but whilst it runs, it's not happy:
Starting can be a bit of a job, sometimes choke needed, sometimes not. Once started it starts it sits at 1,500rpm, no choke quite happily.
The problem is more when I'm riding, I'll come to a stop at a junction, clutch in and the engine's idling at 3,000-4,000rpm. Throttle is closed, I checked that. Sometimes it slowly drops down to 1,500rpm, other times it just sits there until I move off again.
I've checked for air leaks and that's all fine. The pilot mixture screw was originally at 1 turn out from closed, so I reset it to the Haynes spec. 1 and 5/8 turns and then tried to tune it by adjusting for maximum revs. The problem with that is the engine just seems to get faster the more I unscrew the screw - there's no obvious point of max revs. I also noticed that it's now idling at 1,500rpm when I start the engine and the throttle screw isn't even touching the throttle arm, so I guess the butterfly is fully closed.
I'm pretty sure this is something to do with fuelling - ignition looks fine, sparkplug is a nice light tan colour and there's a reasonable spark when I crank her on the starter motor.
At the moment this is effecting my riding as I need to worry about the engine when I should be worrying about the road and getting all those pesky lifesavers in. I'm tempted just to buy a new carb, they're not too pricey, but I hate admitting defeat!
Thanks,
Andrew. |
| Odie |
 Odie World Chat Champion
 Posted: 19:17 - 14 Jun 2011 Post subject: |
make sure the throttle cable has free play, i.e its not tight and pulling on the butterfly linkage and holding the throttle open slightly.
Also, reset the mixture to the stock setting, the mixture screw only effects the carb at tick-over and up to about 1/4 throttle at a time.
here is some info that might help or it might not.
Pilot fuel mixture screw settings, float level and pilot jet size also affect high-rpm, 0 to 1/8 throttle maneuvers. Too lean, will cause surging problems when the engine is operated at high rpm at small throttle openings! Opening the mixture screws and/or increasing pilot jet size will usually cure the problem.
NOTE: A rich problem gets worse as the engine heats up.
If the throttle is lightly "blipped" at idle, and the rpm drops below the set idle speed, then rises up to the set idle speed, the low speed mixture screws are probably set too rich: try 1/2 turn in, to lean the idle mixture.
NOTE: A lean problem gets better as the engine heats up.
If the throttle is lightly "blipped" at idle, and the rpm "hangs up" before dropping to the set idle speed, and there are no intake leaks and the idle speed is set at less than 1000 rpm, the mixture screws are probably too lean: try 1/2 turn out, to richen mixture. Be sure there are no intake leaks and the idle speed is set at less than 1000 rpm ____________________ You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat." |
| Noxious89123 |
 Posted: 20:50 - 14 Jun 2011 Post subject: |
Interesting... My otherhalf has a GS125, same engine as the GN. Her bike will also idle at around 4k when it's warmed up. It's currently dead atm, will start and run for a short while, but then dies and refuses to start for a while, lots of afterfiring whilst cranking the engine over. Got a new plug, same problem. Think it's running rich, as the old plug was black (and dry) when removed. ____________________
| Odie |
| Paddy Blake |
| ajc219 |
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 08:31 - 16 Jun 2011 Post subject: |
| Odie wrote: | make sure the throttle cable has free play, i.e its not tight and pulling on the butterfly linkage and holding the throttle open slightly.
If the throttle is lightly "blipped" at idle, and the rpm "hangs up" before dropping to the set idle speed, and there are no intake leaks and the idle speed is set at less than 1000 rpm, the mixture screws are probably too lean: try 1/2 turn out, to richen mixture. Be sure there are no intake leaks and the idle speed is set at less than 1000 rpm |
isnt its suppose to be turn out to lean more and turn in to richen? Its an air channel on the pilot circuit after all - source Honda workshop manual but I believe its the same as the carbs are either Mikuni or Kehin etc |
| Odie |
| ajc219 |
| Noxious89123 |
 Posted: 21:27 - 17 Jun 2011 Post subject: |
Can you post / PM a RapidShare link? I have an account for that, so not a problem. ____________________
| ajc219 |
The last post was made 15 years, 148 days ago. Instead of replying here, would creating a new thread be more useful? |
