| Piercee100 |
 Piercee100 Trackday Trickster
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 07:34 - 21 Jun 2011 Post subject: |
ill tell you right now a kh front end is in no way an upgrade,
they use a cable operated caliper,
you could get a complet front end of another bike swap the stems out do it that way,
but i doubt its worth the effort unless you happen to pick up one exceedingly cheap,
you'll need the complete front end including
wheel, caliper, yokes, brackets etc,
i have a 65 vespa which supposed to have 8" wheels but has 10" instead, but runs the stock brakes, needless to say, they are fucken shit, so shit that i have to some times have to use my feet as well as the gears and brakes all in concert,
suck it up, thats are just what old bikes are about, crap brakes, crap suspension, crap handling, ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| yen_powell |
 yen_powell World Chat Champion
| Piercee100 |
| stutterin' sam |
 stutterin' sam Nova Slayer
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| binge |
 binge Emo Kiddy
 Posted: 10:55 - 21 Jun 2011 Post subject: |
I've been on the mini-bike scene for a while now. And the genuine CRF50's are drum front and rear.
There are a few mods you can do to improve them.
Mod the actuator arm, to make it longer, this will give you much more leverage on the drum operation, and give a much stronger bite.
The problem you get with this is the shoes over-heating. Which could already be the problem you are getting. Sometimes the "power" isnt a problem, it's the grip.
Take the wheel off, and take the shoes out. Using a grinder, cut a pattern into the shoes. This will help when you go through water. It will however, make them wear out a little quicker, but shoes come in at around £5 for a set. So it's no biggie.
Change the front end. You dont necessarily need to buy new forks. Changing the wheel to a disc wheel would be a start, then you can make up a bracket for a caliper which works in a similar way to the rear caliper bracket on most bikes.
So you have a hole which the axle goes through, then another hole which the little stub on the fork leg sits through, and holds the bracket in place.
Ben |
| truslack |
 truslack World Chat Champion
| kramdra |
 kramdra World Chat Champion
 Posted: 12:09 - 21 Jun 2011 Post subject: |
caliper hanging on some bodged bracket? nope, dont do it. that shit needs to be strong, and correctly aligned.
First thing, its probably full of brake dust. this is bad, and will reduce performance, so clean it out.
Get it some new shoes! they are cheap! do it.
Clean the hub while your at it, grease the cam arm, but not too much.
Then, get a new cable, becuase they stretch.
Rear brake, same as above, but check the pivot (centrestand?) and grease it.
Then adjust them correctly. This takes some practise (in my case anyway). Set it so that you can just feel the brakes with them off, when pushing it around, then go back a turn or two. |
| MarJay |
 MarJay But it's British!
| binge |
 binge Emo Kiddy
| stinkwheel |
 Posted: 14:21 - 21 Jun 2011 Post subject: |
One thing that would make a big difference is to upgrade the cable. I made my own last time using cable that's twice as thick as standard and it made an enormous difference.
Another thing I've done on bikes with less than adequate brakes before is to fit a modern japanese span-adjustable lever. The pivot is located fUrther from the bars with these giving you a lot more leverage.
What I've used in the past for this is a Kawasaki cable operated clutch lever fitted upside down. You can use the clutch idiot switch as a brake light switch. Make sure you get ones with a straight lever, some are curved for fitting on clip-on bars.
I've also seen people lengthen the brake arm on the drum. Gives you more braking power but at the expense of having to adjust more frequently.
All that said, a new set of pads and a service (which includes removing, cleaning and greasing the cam pivot) can make a world of difference.
Ok. That's modern stuff. Now for some old fashioned stuff. Your pads need to fit the drums. The more pad touching the drum the more friction you have. So, get your new pads and draw a grid on them using chalk, maybe 1cm squares. Now fit them and spin the wheel while applying the brake. Remove them again. Any areas where the chalk has rubbed off, sand them down.
Redraw your grid and repeat the process until all the chalk is rubbed off when you apply the brakes. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Piercee100 |
| trisers |
 trisers Scooby Slapper
| Piercee100 |
| trisers |
The last post was made 14 years, 298 days ago. Instead of replying here, would creating a new thread be more useful? |
