Electrical fault - getting desperate! NSR 125r
 Topic moved: from General Bike Chat to The Workshop by G (24 Aug 2004 - 16:39)
alt
PostPosted: 14:34 - 24 Aug 2004    Post subject: Electrical fault - getting desperate! NSR 125r Reply with quote
Hey folks,
I posted this here before but to no avail.
I hadnt run my NSR 125 '00 for quite a long time, when I went to run it last week it started fine, but the elctronics wouldnt work. The indicators/headlights were very flaky, sometimes they would work, sometimes they wouldnt. Then I turned on my headlights/indicators the RPM meter and Temp gauge went dead, until i turned the indicators/headlights off.
Yesterday I went to start the engine to give it a run, and nothing happened. It is completely dead. I've checked all obvious things like battery charge (its charged fully) and connections. I have also resorted to changing the CDI unit and relay unit that sits beside it.
I have found what looks to be another relay unit behind the air-box, does anyone know what this is or if it could be related to my problem? Does anyone have *any* idea what this could be?!
McJamweasel
BCF Junkie
PostPosted: 14:36 - 24 Aug 2004    Post subject: Reply with quote
I would guess that its a problem in the wiring loom somewhere. What you need to do is get a wiring diagram and then go and check every wire/connection in there.
BCF: Be yourself, just don't be an arse.
alt
PostPosted: 14:39 - 24 Aug 2004    Post subject: Reply with quote
eek! Shocked
Does anyone know where id get a wiring diagram online? I'm almost certain I came across a link to it before... oh how the time has passed!
PostPosted: 16:39 - 24 Aug 2004    Post subject: Reply with quote
I've had a similar problem before on an NSR, was a the fuse blown.
Have you tried bumpstarting it?
Give it a few bumpstarts if you haven't.
My RS with a dead battery displays similar signs; though is kickstart only, so always starts anyway.
Odie
PostPosted: 16:46 - 24 Aug 2004    Post subject: Reply with quote
Try cleaning your earth terminal on your battery and the frame where it attaches to.
hope this helps
You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat."
c058y
PostPosted: 19:02 - 24 Aug 2004    Post subject: Reply with quote
I recently had the exact same problems with my NSR. It turned out to be corroded wires within the wiring loom. I didn't have the time to check all the wires within the loom so I got my mechanic to sort it out. It cost me around £120, the majority of it was spent on labour.
I put a post on here regarding this: https://www.bikechatforums.com/viewtopic.php?t=29643
I hope this might help you.
The last post was made 21 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 16 - Page Size: 48.69 Kb
