| bennell09 |
 bennell09 Renault 5 Driver
| DrDonnyBrago |
| johnsmith222 |
 johnsmith222 World Chat Champion
| chillyman0 |
 chillyman0 Nearly there...
| bennell09 |
| P.addy |
 P.addy Red Rocket
| Willson |
 Willson Traffic Copper
| DrDonnyBrago |
| bennell09 |
| DrDonnyBrago |
| bennell09 |
| DrDonnyBrago |
| bennell09 |
| DrDonnyBrago |
| bennell09 |
 Posted: 17:55 - 21 Jun 2011 Post subject: |
| DonnyBrago wrote: | | bennell09 wrote: | its not been off while ive owned the bike and i cant contact the previous owner to find out if they had. if i recall when i pumped the lever i did see tiny bubbles rise from the tiny hole each time i pumped the brake. so the only way to solve this is by getting the banjo loose. excuse my ignorance but what does "priming" the master cylinder mean mate
thank you |
Priming the master cylinder means getting the air out and filling it with fluid so that it is actually pumping fluid when you squeeze the lever. Imagine a syringe on it's side with air in it and a small amount of fluid at the bottom, if there is too much air then when you squeeze it you will be pushing air not fluid. If you empty your MC then fill it up and start pumping you are probably not actually pushing any fluid out.
If you cannot get the banjo off then tapping the brake lever in short sharp movements until you can no longer see any bubbles might be enough, certainly should be able to get some pressure built up in the lever that way. Every time you see a bubble it is one less bit of air in your brakes so keep doing it . Unbolting the MC from the bars (with the res cap on) and moving it around to angle it so the air can find it's way out of the little hole (whilst tapping the lever) might also work. |
okay, i did everything you said and everone else and the brake has improved but i can still push the bike with the front locked on but i have to use alot more "push" to move it, first i eventually managed to get the banjo loose and did what you said, after that the brake seemed a touch less soft, then i removed the MC from the bars and moved it around to untrap any air, this made no difference, then i remove the res cap and pressed the lever and a huge bubble came out follwed buy a few small ones, i did this for 20mins untill all the air had been reliesed, this did improve the soft spongy feeling but its still there, i bled the brake 3 times afterwards and pumped the brake afterwards for another 15-20 mins but only with 1-2 tiny bubbles. so lastly i removed the caliper and moved the piston out slightly to make the pads closer and this has improved the braking feeling alot but the brake pads are now constantly rubbing the disk. still all this and i can move the bike with the brake on full? i also cleaned the disk and sandpapered the pads to remove the shine off them during the bleed process, there are no leakes, everything moves freely so ive got no idea. could it just be the fact the pads are new? |
| DrDonnyBrago |
 Posted: 19:52 - 21 Jun 2011 Post subject: |
| bennell09 wrote: | okay, i did everything you said and everone else and the brake has improved but i can still push the bike with the front locked on but i have to use alot more "push" to move it, first i eventually managed to get the banjo loose and did what you said, after that the brake seemed a touch less soft, then i removed the MC from the bars and moved it around to untrap any air, this made no difference, then i remove the res cap and pressed the lever and a huge bubble came out follwed buy a few small ones, i did this for 20mins untill all the air had been reliesed, this did improve the soft spongy feeling but its still there, i bled the brake 3 times afterwards and pumped the brake afterwards for another 15-20 mins but only with 1-2 tiny bubbles. so lastly i removed the caliper and moved the piston out slightly to make the pads closer and this has improved the braking feeling alot but the brake pads are now constantly rubbing the disk. still all this and i can move the bike with the brake on full? i also cleaned the disk and sandpapered the pads to remove the shine off them during the bleed process, there are no leakes, everything moves freely so ive got no idea. could it just be the fact the pads are new? |
most important question - when you pull the brake lever is it reaching the bar or is it reaching a point where it will goes hard and cannot be pulled any further? Is there any resistance at all in the lever?
If it is reaching the bar and or has no resistance then there is still a lot of air in the system. Does the brake line loop around higher than the MC? If there are other high points in the system (like loops in the line, line splitters etc) then you can get air accumulating here? Did you try bleeding fluid from the brake caliper banjo? You can also get air trapped here that is very stubborn to remove.
Lastly how are you bleeding from the nipple (do you have a one way valve or are you using a tube dipped into fluid?), could it be that when you are bleeding the fluid air is returning back into the caliper? Was is a fresh non shaken bottle of fluid you are using, bubbles take ages to settle out so if the bottle has been shaken then it will introduce air into the system (one of the reasons I don't like back bleeding with a syringe is because it is difficult not to aerate the fluid).
Whenever I install new pads I can quite easily lock the wheel, they really perform rather well even from the start. Don't ride the bike until you get a decent bit of stopping power as it will end badly.
If you try again tomorrow the air will have risen to the highest points, these will be the MC, any high points in the brake line (bad, these are hard to remove - position the MC so that it is the highest point overnight), the banjo at the caliper and the bleed nipple at the caliper.
Bleed at the MC first. Apply pressure to the lever, open the banjo and close it again before you have pulled the lever the whole way down. Pump the lever a few times to get the firmness back and repeat. Do this 5 or six times from the MC banjo, then the caliper banjo then finally bleed from the caliper nipple. |
| bennell09 |
 Posted: 22:24 - 21 Jun 2011 Post subject: |
| DonnyBrago wrote: | | bennell09 wrote: | okay, i did everything you said and everone else and the brake has improved but i can still push the bike with the front locked on but i have to use alot more "push" to move it, first i eventually managed to get the banjo loose and did what you said, after that the brake seemed a touch less soft, then i removed the MC from the bars and moved it around to untrap any air, this made no difference, then i remove the res cap and pressed the lever and a huge bubble came out follwed buy a few small ones, i did this for 20mins untill all the air had been reliesed, this did improve the soft spongy feeling but its still there, i bled the brake 3 times afterwards and pumped the brake afterwards for another 15-20 mins but only with 1-2 tiny bubbles. so lastly i removed the caliper and moved the piston out slightly to make the pads closer and this has improved the braking feeling alot but the brake pads are now constantly rubbing the disk. still all this and i can move the bike with the brake on full? i also cleaned the disk and sandpapered the pads to remove the shine off them during the bleed process, there are no leakes, everything moves freely so ive got no idea. could it just be the fact the pads are new? |
the lever does reach the bar with a ample amount of squeeze so there is some resistance but nothing like ive felt before on a front brake its too soft. the brake line raises around 10cm above the MC which loops down to the caliper. i didnt try the caliper banjo i stupidly forgot that . ive been using a tube into a bucket, pulling the lever in a little then cracking the nipple-closing it then relising the lever and repeting untill the fluid pours itself freely so i dont think air can go back into the system like this. i had the bottle sat on the shelf for a day to allow to settle before i used it? tomorrow ill bleed the MC using your banjo method for both the MC and caliper and see if that hopefuly does the trick then ill hang the system so that the MC is attached to the bars and the rest of the system is below the MC then repete the banjo trick and bleed to reliese the air that might be caught in the highest point of the system. youve been a massive help mate hopefuly itll get it fixed tomorrow if not im going to dump all the fluid from the line, MC and caliper and start again |
| bennell09 |
 Posted: 20:00 - 22 Jun 2011 Post subject: |
so today, i did everything you said...again , baught 350ml of fluid and ran the entier lot through the system. after around 100ml bubbles stopped showing but i used the rest to be on the safe side. this did make the lever a fair bit more harder to squeeze but i can still get it to reach the bars but i do have to use alot of pull. the actual braking has improved quite alot and i can only just and i mean just push it for 10-15cm then i run out of energy then its off for a rest so things are improving. ive cable tied the lever to the bar as someone suggest to see if anything improves by tomorrow if not ill get myself a radial brembo and a new nissin caliper |
The last post was made 14 years, 298 days ago. Instead of replying here, would creating a new thread be more useful? |
