| Polarity |
 Polarity Derestricted Danger
 Posted: 16:02 - 24 Aug 2004 Post subject: chain tension |
Just wondering if anyone can help, not sure how to adjust the chain tension on a honda nsr 125 rr. Any idea's would be a great help.  |
| Frost |
 Frost World Chat Champion
| alains |
 alains World Chat Champion
 Posted: 17:07 - 24 Aug 2004 Post subject: chain |
you must turn each side at the same level . control if it's not too thight after blocking the central bolt . if the picture is not good enough mail me i will give you a full one asaniard@neuf.fr ____________________ the worst day fishing is better than the best day working |
| The Tot |
 The Tot World Chat Champion
 Posted: 17:16 - 24 Aug 2004 Post subject: |
Your service manual should tell you how to do it, but other wise, here's a basic step. Like DaFrostyOne said, only bother doing it if your chain is totally slack:
1) Use a centrestand or paddock stand to make sure that the rear wheel is off the ground and the bike is balanced.
2) One side of you chain should feel tighter than the other as you try to push it up, rotate the rear wheel until the tight spot of the chain is at the bottom, i.e beneath the swingarm
3) Use a spanner to undo the rear spindle nut which connects the wheel rim/sprocket etc to the swing arm just enough to allow you access to the adjuster screws and bolts adjacent to the swingarm (it is running through the swingarm in a horizontal direction). As you undo the spindle nut, the swingarm should flex outwards like a bow and should return to a straight position once the nut is done up.
4) With a correct size spanner, slacken off the adjuster bolts taking particular caution NOT to ROUND them off... do not over-tighten. Do this on the side with the chain LAST!
5) Once you can see the slack being taken up (there's usually between 35mm - 45mm of free play in the chain where it can be pushed down at the midpoint of the bottom run of the chain)
6) Note the adjuster marks on the swingarm and do it on the otherside.
7) check the slack in the chain again and readjust if ammendments are required.
8) Retighten the spindle nut PREFERABLY using a torque wrench or some really jammy guesswork (not doing so will damage the thread of the nut and f**k you up basically)
9) It maybe necessary to redo the process again due to the swingarm bowing out as mentioned in step 3.
10) check that the wheels are running true and straight and you're off.
NB... best time to lube the chain before you ride..
hope this has been of help!  ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| McJamweasel |
 McJamweasel BCF Junkie
| mr jamez |
 mr jamez World Chat Champion
The last post was made 21 years, 166 days ago. Instead of replying here, would creating a new thread be more useful? |
