| el_oso |
 el_oso World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 18:52 - 20 Jun 2011 Post subject: |
Sounds like you still have air still trapped in there.
Tape the brake lever back to the bars overnight. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Blue_SV650S |
 Posted: 19:25 - 20 Jun 2011 Post subject: |
You need to scrape the crud out of the seal recesses! that is all it is*
*When you said 'thoroughly' did you get all scrapy on its behind if not then above is true!!?? ____________________ The purpose of life is to fight maturity. |
| el_oso |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 00:07 - 21 Jun 2011 Post subject: |
Start from the beginning again.
The pistons should go back in without much persuasion at all. Mine do anyway!
Remember to lube the pistons with red rubber grease that will help.
Also, just as a word of warning the blue spots are all most impossible to bleed using the old fashioned method. The best thing I got for mine was a set of 'speed bleed' nipples. Just means you can pump the lever without having to keep shutting the nipple at the end of the travel and starting again.
I remember running about 5 complete resoviours through before they were stiff, if not more. If you can bring the bar back to the handlebars then you have air in the system.
I found the blue spots pretty nice to work on. Just bleeding them that's impossible! ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| weasley |
 weasley World Chat Champion
| el_oso |
| totalllama82 |
 totalllama82 Crazy Courier
| el_oso |
| MarkJ |
 MarkJ World Chat Champion
| el_oso |
| 0l0dom0l0 |
 Posted: 21:58 - 22 Jun 2011 Post subject: |
| the_godfather wrote: | just an update. rebuilt and re-bled today. still no change.
tried the classic tried and tested method of bleeding. looks like the master cylinder is hardly pushing any fluid through. after pumping the lever 20-30 times then holding the lever to the bar and cracking the nipple virtually no air or fluid moves out the nipple connected hose.
time for a master cylinder rebuild methinks.
while i have everything off i think i'm going to change the pads and get some HEL/goodridge braided lines.
looks like I'm going to be cycling to work for while now. |
The problem is, the blue spots won't pull any fluid through when the system is empty. To me what you are describing sounds like the system is full of air.
Have you tried to reverse bleed them yet? Just get a syringe and force the fluid up through the calipers. It's the only way you can get them to pull fluid through in my experience. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| el_oso |
| evoboy |
 evoboy World Chat Champion
 Posted: 23:04 - 22 Jun 2011 Post subject: |
Have you bled the master cylinder?
I have Thundercat calipers on my TRX, dead easy to bleed using the old style method. Solid feel at the lever. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| totalllama82 |
| el_oso |
The last post was made 14 years, 226 days ago. Instead of replying here, would creating a new thread be more useful? |
