| chrismeister |
 chrismeister Nitrous Nuisance
 Posted: 14:56 - 23 Jun 2011 Post subject: Zx6r front fork setup |
Slightly concerned / interested about what the settings should be on my front forks
If i look at the two screws on top of the yoke they are at different heights, one appears to be screwed in more than the other, is this how it's meant to be?
Also, the two screws at the bottom of the forks, next to the wheel bolts, they are also at different levels, just like at the top, is this how it should be too?
The bike is a 97' zx6r. ____________________ https://www.tartycarper.co.uk |
 ..... Quote Me Happy
| BigGeeking |
 BigGeeking Scooby Slapper
 Posted: 15:07 - 23 Jun 2011 Post subject: |
| chrismeister |
 Posted: 15:10 - 23 Jun 2011 Post subject: |
thanks for that, those settings check out with another resource.
I found somewhere else that what you see shouldnt matter too much in regards to the level of the screws, it's the amount of clicks that's important, so i may be overreacting.
Will set to stock and go from there. ____________________ https://www.tartycarper.co.uk |
| chrismeister |
 Posted: 15:55 - 23 Jun 2011 Post subject: |
Just to double check....
Bottom adjusters are the compression.
What ones on the top are the preload and the rebound??
The pin the in the middle or the larger head around it, which is which? ____________________ https://www.tartycarper.co.uk |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| chrismeister |
 Posted: 19:14 - 23 Jun 2011 Post subject: |
nice one, i'll reset them so i know it's all set right...
Now i know it's all set correctly I can start practicing corners properly! ____________________ https://www.tartycarper.co.uk |
The last post was made 14 years, 233 days ago. Instead of replying here, would creating a new thread be more useful? |
