walls
blahheed
PostPosted: 10:17 - 24 Jun 2011    Post subject: walls Reply with quote
for house cavity wall insulation.
i drilled a hole in the wall only to find the brick is like an outer skin with a gap behind it.
the outside walls have the tell tale signs of having it done and have a certificate from 2001
i thought the balls of insulation was supposed to be behind that and would come out ?
would the structure be breeze blocks or similar for the main walls then the brick to make it look nice ?
The Artist
PostPosted: 10:21 - 24 Jun 2011    Post subject: Reply with quote
It depends where it is in the building.
From what you have said it sounds like you just drilled through the pretty bricks into a cavity. Yes breeze blocks are part of the main structure.
Insulation isn't always in the form of balls. It is a horrible glass fibre type stuff here.
mjn51
PostPosted: 10:41 - 24 Jun 2011    Post subject: Reply with quote
older houses had the cavity filled with expanding foam insulation if done after they were built. telltale sign are the holes drilled into which the foam was injected.
HTH
M.
The Artist
HTH
M.
Like in the borrowers
blahheed
PostPosted: 11:21 - 24 Jun 2011    Post subject: Reply with quote
i drilled as am putting up a carport, on the gable end of the house about 8 feet high
nothing came out of the hole as you would imagine,
looked like an empty space
sebastianw
PostPosted: 11:22 - 24 Jun 2011    Post subject: Reply with quote
Sometimes the glue that's supposed to hold the polystyrene balls of mineral fibres together fails and the insulation drops to the bottom of the cavity. How old is the house?
blahheed
PostPosted: 11:25 - 24 Jun 2011    Post subject: Reply with quote
house is 1970's
sebastianw
PostPosted: 12:03 - 24 Jun 2011    Post subject: Reply with quote
bikemad wrote:
house is 1970's
100mm Breeze block inner, 50mm cavity, 105mm brick outer.
Drill a hole at the bottom of the wall and see if anything comes out.
If not what guarantee came with it?
t121anf
PostPosted: 13:12 - 24 Jun 2011    Post subject: Reply with quote
my cavity wall insulation is like white cotton wool balls.
same in 2 houses I have had done.
Steve-D
PostPosted: 15:36 - 25 Jun 2011    Post subject: Reply with quote
Might of used shitty galvanized steel wall ties and had them replaced?
What sort of spacings are the holes in the wall at?
www.southwestbikers.com
Dazbo666
PostPosted: 18:00 - 25 Jun 2011    Post subject: Reply with quote
The Artist wrote:
....Insulation isn't always in the form of balls. It is a horrible glass fibre type stuff here.
Got the glass fibre stuff at our place... as I found out last summer when fitting a garden hose connection to the outside wall, and having to drill a hole thru from the downstairs bathroom
Word of the day : DILLIGAF
The last post was made 15 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.18 - MySQL Queries: 15 - Page Size: 66.52 Kb
