rebound and compression settings
T0MMY
PostPosted: 17:42 - 24 Jun 2011    Post subject: rebound and compression settings Reply with quote
Anyone got any tips for a baseline for the suspension on my ZX6R G2 (75-80kg rider)? I have a trackday tomorrow so I will play with the settings a bit between sessions but it would be useful to have a starting point as it handles pretty poorly at the moment. The preload is set ok so I'm more interested in the damping.
I've hardly ridden the bike yet but gave it a bit of a run after work and found it spins up the rear wheel a little too easily out of corners. I was coming off a roundabout leant over reasonably far at about 70mph and found the back wheel skipped and bounced and slid out quite far under hard acceleration. I suspect this might be due to too much compression damping but I don't really have much experience with setting up suspension.
It also feels like the front flops into corners too much and feels like it's trying to tuck under but it does have a leaky fork seal so that may be the culprit! It also has a 120/70 on the front which is steeper than standard so will add to that I guess.
ZX6R + CBR600RR
PostPosted: 18:16 - 24 Jun 2011    Post subject: Reply with quote
My 2p.
Pay the bloke a tenner to set it up.
You have lost some fork oil. How old is the oil? Are the springs past their best?
You might only be doing a trackday, but it comes across that you want to actually improve.
Learn from the professionals or set to stock and start adding clicks.
T0MMY
PostPosted: 18:24 - 24 Jun 2011    Post subject: Reply with quote
If I can get a setup at the track for a tenner I'll go for that. I thought it would be a lot more and not worth it if I'm looking at fixing the fork seal, changing the fork oil and maybe getting a new shock on there plus I will be getting some decent race scrubs on it too.
I would like to improve but really I just want it to handle at least as well as my venerable CB-1 Laughing I'm still tempted to just take that bike instead frankly as it's awesome for what it is and it would be fun trying to keep up with the superbikes Cool
ZX6R + CBR600RR
PostPosted: 18:46 - 24 Jun 2011    Post subject: Reply with quote
Thinking The tech people might not want to work on a bike with a leaky seal?
Whatever you choose to do including if you do take the CB-1, have a butchers at this.
https://www.moto-racing.co.uk/Guides/motorcycleSuspensionSetup.htm
T0MMY
PostPosted: 19:41 - 24 Jun 2011    Post subject: Reply with quote
Thanks for the link, should be useful. Thumbs Up
The CB-1 is really well set up, handles beautifully for what it is and has utterly superb tyres. It's limited by the ground clearance more than anything else and by the lack of power so I don't think I could go a lot faster on it. I bought the ZX6 to improve my riding by trying to reach its (much higher) limits but with the current set up I suspect that tomorrow I will be limited by the rear suspension more than my own ability (or lack thereof).
ZX6R + CBR600RR
neatbik
PostPosted: 19:50 - 24 Jun 2011    Post subject: Reply with quote
You will need to get that fork seal sorted out really before anything else.
Other than that, try setting everything in the middle and take it for a ride.
Post back with your findings and we can take it from there.
When i had my CB1 i very nearly fitted a pair of cbr400 forks (go straight in and are adjustable) and a 'blade rear shock.
Would have transformed it i reckon.
T0MMY
PostPosted: 20:35 - 24 Jun 2011    Post subject: Reply with quote
As I said, biggest problem with the CB-1 is ground clearance and rearsets are hard to find for it. Also hard to get race scrubs for it, plus it's still a pretty slow bike. All in all I decided it was better to get something more track orientated as it'll be easier to get suitable parts for it. I never felt the CB-1 was let down by the suspension really as it had more grip on track tyres than the power could overwhelm anyway.
ZX6R + CBR600RR
SirEdward
PostPosted: 22:10 - 24 Jun 2011    Post subject: Reply with quote
Excellent link. I'm the process of transforming my 750 GSX-R, suspension feels too soft for my kind of riding - bike's all over the place. Razz
"Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune""
Old Git Racing
PostPosted: 01:15 - 25 Jun 2011    Post subject: Reply with quote
Yeah right, just take your CB-1 and stay in your little comfort zone trying to keep up with the superbikes but not really doing it but it don't matter cos your on a CB -1.
You WONT get a suspension set up for a 'tenner' at a trackday, and most I know wouldn't entertain it with a leaking fork seal. You bought a ZX6R to improve but you'll take it to a trackday with a leaking seal, get real.
Put some time in and get it right before you go, at least to standard spec including fork seals, and yes, your lack of ability will far outweigh any suspension settings cos a ZX6R will run rings around a CB-1 rear sets or knackered suspension included.
Listen, I hope you have a good day but like with everything else you get out of it what you put in. If you want to just have a bit of fun then rock on, but if you want to really improve your riding on trackdays stop pissing about and get serious.
OGR
OGR
PostPosted: 10:00 - 25 Jun 2011    Post subject: Reply with quote
That link is too complicated.
You want this:
https://www.bikechatforums.com/files/setup.zip
It is a PDF but too large to attach to a post in BCF. However, its only three pages long and explains pretty much all you need to know.
PostPosted: 10:03 - 25 Jun 2011    Post subject: Reply with quote
OGR
OGR
I think you're being a bit harsh to the feller. Jay12329 from this very forum had his 675 suspension set up at a trackday... but I can't remember how much it cost. It wasn't that expensive though (My brain is saying £25 but I'm not sure if that is right?)
Its not like he's racing, and even if he were, is it really that serious? Sure, he's got a leaky fork seal but he only got the bike the other day! Maybe the OP shouldn't be worrying about suspension setup until he's sorted the leak and got decent tyres etc, but I think the tone of your post comes across as a bit nasty TBH.
Which is weird, because normally you seem to be OK with people on here... unlike some posters (Sometimes myself included!).
Old Git Racing
PostPosted: 10:35 - 25 Jun 2011    Post subject: Reply with quote
Tommy, sorry about that, reading it now it does come across as nasty, you're right Marjay. I can be a dick sometimes like anyone and I was posting that crap.
On a more helpful note Kwaks usually are oversprung so you need to get the sag set up first and go from there. At a track they usually charge 30-40 quid to set it up but just find someone who looks fast on a similar bike and ask them their opinion first. Get tyre pressures right for the track, stick a tie wrap round a fork leg (the one not leaking Smile ) and set the front so you have about 10mm of movement left after your hardest braking. set the rebound so the forks come back up progessively, not just springing back up when you come off the brakes, bet you end up not far from maximum on rebound.
At the back its more about feel. Set compression so the bike doesn't sit down too much when you get hard on the gas, but not hard so that itcompromises grip on bumps. Set rebound so the back comes up at the same speed as the front, again bet its close to max.
Hope this is a bit more helpful and have a great day.
OGR
T0MMY
PostPosted: 18:26 - 25 Jun 2011    Post subject: Reply with quote
Didn't get a chance to read that before I went...
ZX6 was ok, first session out it was way too soft at the front under braking and the back was bouncing around a lot leading to 2 BIG slides. I cranked up the rebound and compression at both ends and it was much much better but I was really held back by the lack of grip of the rear tyre which was spinning up out of just about any corner and really limiting lean angles too. It ruined the day to a certain extent as I was having to ride below what I would consider my limits but I guess I learnt a bit about being smooth.
For the record, a CB-1 with well set up suspension and Michelin Power Ones does handle better than a ZX6R with a rear BT020 and poor damping. I've no doubt I was quicker on it in the corners as it just has so much more grip.
All in all just glad I made it home as I had at least one "moment" on every lap to the point where sliding the bike out of certain corners was starting to be the norm.
ZX6R + CBR600RR
SirEdward
PostPosted: 18:39 - 25 Jun 2011    Post subject: Reply with quote
Reduce rebound by 50% & compression by 25% of what you have on the rear shock, otherwise the rear wheel will spin out of corners, because you're not fat enough. Very Happy I've cranked up compression on my old 750 SRAD due to 11 y.o. suspension, and it is more stable now during braking & acceleration - a new bike. Wink
jay12329
Dr. Evil
PostPosted: 19:30 - 25 Jun 2011    Post subject: Reply with quote
I had it done by 100% suspension at a no limits tack day.
Its was 40quid for a full baseline setup for my weight, and then he made adjustments after every session based on my feedback. This not only made the bike much better on track it gave me much more confidence on the road. The best 40quid I ever spent on bike 'upgrades'!
hth
J
Old Git Racing
PostPosted: 20:31 - 25 Jun 2011    Post subject: Reply with quote
Have you measured the sag? Still sounds like too much rear preload to me, if it is it will overcome the damping and not let it work properly.
Reducing compression and rebound will perpetuate the problem if the spring is too hard, particularly rebound cos as the suspension extends too quickly you loose grip.
OGR
T0MMY
PostPosted: 20:41 - 25 Jun 2011    Post subject: Reply with quote
One of the instructors went over the suspension settings for me and we tried various things.
Lower damping (both ways) on the rear led to the back wheel skipping out of corners, the best setup was everything pretty much as stiff as possible. With this setup the bike felt good at the front and stable all round but I was still unable to get the power down as easily as I would have liked and lean angles similar to what I could easily achieve on the CB-1 led to the back wheel drifting wide (but in a much more controlled way than in the early sessions). Applying power, therefore, was somewhat nerve racking Laughing
The guy agreed with me that the tyre just didn't have the grip to push harder. To be honest though, we should put this in perspective...I had no trouble keeping up with most of the guys in inters and overtook a lot more than I got overtook, I think I was just spoiled by the excellent tyres on my CB-1 and am disappointed with the grip of this bike. The bike was far from hopeless, I just wish I was being held back by my own lack of skill or even the true capabilities of the bike rather than just a lack of grip from one tyre.
EDIT: Forgot to say...the other possibility is that I was going off the edge of the tyre as it doesn't have a very steep profile. The little curls of rubber you get were being pushed right off the edge of the tyre so I guess it's possible though a little surprising considering I never felt like I was leaning all that far.
ZX6R + CBR600RR
skyline
PostPosted: 11:31 - 27 Jun 2011    Post subject: Reply with quote
Bt020's and 021's are shockingly poor on track. At Mallory I went out on bt021's for the morning sessions as I didn't want to put my slicks on due to not knowing which way the weather was going (cold morning and lack of tyre warmers put me off to!) and I lapped 6 seconds slower on average though 3 sessions than I did running wets in the wet a few months earlier. Slicks back on after that and my times dropped straight down even though I didn't feel like I was leaning more or pushing all that much harder but I sure as hell passed more people lol! Bt021's I was riding would spin up far to easily without having to push to much out of corners. For me Id say tyres have the biggest impact on how I ride, although I think Ill be looking at getting suspension set-up done next perhaps Smile
Deckx
PostPosted: 12:27 - 27 Jun 2011    Post subject: Reply with quote
MarJay wrote:
Forgive me for being blunt but:
Its obvious from the vid what you've done. You've decided the handling of a near ten year old sportsbike must be 'shit' so you've turned a load of adjusters up without doing any experimentation or having any evidence to back up any of the changes you've made. You've ended up making the bike near unrideable by just making the suspension 'harder'.
This doesn't work.
The trick is to get the suspension as soft as you can without allowing it to bottom out etc, because this will allow the suspension to work in its idea range (which is about a third of the way down from completely topped out). By turning everything up you've managed to make the rear shock stay topped out even with you sitting on the bike which frankly is dangerous (as backed up by the slides you've been having).
Obviously you haven't taken any of Marjays advice from a previous thread Laughing
I was told pretty much the exact same thing by pro racer (Gary Johnson) when he set up my zx6 last year......He said most people wind in the settings too hard and this only makes the tires do the work instead of the suspension.
i thought it was set up ok'ish but he came back after a couple of laps and said it was shit Neutral along with another bike, he spent about a half a day at it.. this was taking out back shock, adjusting preload, had me take the front forks out 3 times Shocked as he kept droppig the oil until he got maximum travel in the forks without bottoming out .. this was with the preload would all the way in.
took it out first and tbh, thought it was a bit too loose and bouncy but he said treat it like a different bike and strangely enough once you get over the initial change the bike feels waaay better..
got a lot more confidence in a couple of corners now... once you get comfortable with the bike moving abit, can actually feel whats happening under you whereas before with everything wound in too hard you get little or no feedback..
Got a K7 Thou last month so hopefully he'll be passing through Thailand on his way back from Macau GP so i’ll get that set up as well... got no excuse anymore for for losing out up the straights Laughing
The last post was made 15 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 114.47 Kb
