| leepick |
 leepick Scooby Slapper
| Pete. |
 Pete. Super Spammer
 Posted: 19:21 - 24 Jun 2011 Post subject: |
It sounds like you have the balancer set wrong. Also, did you just fit the bearings onto the crank then put the crank in the cases? If so you probably have the bearings hugey pre-loaded which will cause early failiure. There is a specific proceedure for fitting the crank which involves heating up the engine cases. ____________________ a.k.a 'Geri'
| leepick |
| P.addy |
 P.addy Formerly known as P.
| leepick |
 Posted: 21:01 - 24 Jun 2011 Post subject: |
Its a bitch of a job getting the engine back out isnt it..
Pete rebuilt my RS, so he knows what hes talking about, but yea teh cases should really be heated... he'll tell you why, but they do make a big deal about it..[/quote]
yeh its a right load of dog muck lol. is there anything u or pete can suggest because i really really really dont want to take the engine back out. ive just posted another link in the forum as i didnt explain much in this one. practically the same tho lol. thanks for the replies. just need the bike running smoothly so i can sell her  ____________________ Aprilia RS125 |
| P.addy |
| leepick |
| Pete. |
 Pete. Super Spammer
 Posted: 23:44 - 24 Jun 2011 Post subject: |
The reason you have to heat the cases is because the bearing is a VERY tight fit on both the crank and the cases. If you just assemble the engine and use the case bolts to pull the cases together you're putting a tremendous amount of lateral load on the bearing races that they are not designed to take. The ballrace cages will disintegrate and then you'll need new piston, barrell and gaskets when the bits get ingested. ____________________ a.k.a 'Geri'
| timsmith |
 timsmith Two Stroke Sniffer
 Posted: 08:25 - 25 Jun 2011 Post subject: |
Have the main bearings been replaced? reading your posts it sounds that only the big end and con rod were replaced? Did the "garage" you used to assemble the crank have the correct kit to do this or was it just pressed up on their fly press. The balance shaft and its gear alignment can be checked without removing the engine from memory. you will need to drain the oil and remove the clutch case to see the gears. they should have marks on them that line up on assembly.
To your original question no it won't get better after it has been run in, sorry
Good luck
Tim |
| leepick |
The last post was made 14 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
