Honda NSR 125R Won't start [UPDATED]
Vexon101
PostPosted: 09:32 - 26 Jun 2011    Post subject: Honda NSR 125R Won't start [UPDATED] Reply with quote
I don't really know much about motorbikes, all I've done Is refill the tank of petrol, changed oil & recharged the battery over night. It still Isn't starting & I have no Idea what to do apart from going to the mechanics.
Here Is a video of me trying to start It up - https://www.youtube.com/watch?v=e5hRO89Acno
Paxovasa
PostPosted: 09:40 - 26 Jun 2011    Post subject: Reply with quote
Check it's getting fuel and producing a spark.
Does it have an immobiliser?
Try giving it a little twist on the throttle while turning the engine over.
Vexon101
PostPosted: 09:48 - 26 Jun 2011    Post subject: Reply with quote
They were my first thoughts, I'll go & attempt to check them later.
When I remove the seat there Is an immobiliser, It's all been connected but I don't think It works.
I wasn't using the throttle much In the video, but I have been turning the throttle a bit when trying to start It.
Paxovasa
PostPosted: 09:50 - 26 Jun 2011    Post subject: Reply with quote
Is the fuel turned on?
Does it have a manual choke?
You could also try removing the air filter, just to see if it will fire up.
Vexon101
PostPosted: 09:56 - 26 Jun 2011    Post subject: Reply with quote
Fuel Is turned on & I was using the choke as I had just woken up & It was quite cold outside and I'll give It a go
PostPosted: 10:01 - 26 Jun 2011    Post subject: Reply with quote
Tried bump starting it. Have you got 2 stroke oil in there.
Also, take the spark plug out and put your thumb over the hole, press the starter button, does it try to blow your thumb away from the hole?
Vexon101
PostPosted: 10:04 - 26 Jun 2011    Post subject: Reply with quote
Haven't tried bump starting It but I will give It a go & there Is 2 stroke oil in there.
I haven't checked the spark plug yet.
alains
did you check the kill switch ?
Vexon101
PostPosted: 10:07 - 26 Jun 2011    Post subject: Reply with quote
@Alains Why do you mean?
Paxovasa
PostPosted: 10:09 - 26 Jun 2011    Post subject: Reply with quote
He means check that you haven't knocked it on.
Although some bikes wont turn over if the kill switch in on.
Vexon101
PostPosted: 10:13 - 26 Jun 2011    Post subject: Reply with quote
The kill switch Is off.
alains
PostPosted: 10:49 - 26 Jun 2011    Post subject: Reply with quote
ok . lift your tank (foxeye) or get access to the plug , take off your plug , connect it to the cap , let it laying on the head then key on and push start button for 4-5 seconds while looking your plug . if you see a blueish spark , it's ok otherwise you may have a stator problem (burned or grounded ignition coils , eventually impulse coil faulty)
Vexon101
PostPosted: 10:55 - 26 Jun 2011    Post subject: Reply with quote
I don't think my spark plug works
https://www.youtube.com/watch?v=6Nv_Fct3i3c
Picture - https://s1134.photobucket.com/albums/m609/Spark_SparkVille/?action=view¤t=SDC16060.jpg seems like a bit of metal Is missing from the top?
alains
PostPosted: 11:04 - 26 Jun 2011    Post subject: Reply with quote
i said take off plug ! then connect it to the cap !
the piece on top of the plug is necessary to be unscrewed otherwise you cant connect the cap
in case , use BR9EIX instead of BR9ECS
Paxovasa
PostPosted: 11:12 - 26 Jun 2011    Post subject: Reply with quote
Looks ok to me. But without the HT lead on you will get nothing.
Remove plug, clip HT lead onto the plug, lay plug across top of engine, presss starter and see if there is a spark.
Do not touch the plug while turning the engine over or you will get an electric shock.
Vexon101
PostPosted: 11:13 - 26 Jun 2011    Post subject: Reply with quote
Ah, I see what you mean now.
Paxovasa
PostPosted: 11:15 - 26 Jun 2011    Post subject: Reply with quote
Ah, I see what you mean now. Do I need a wrench to unscrew It?
If you have the took kit for the bike, you should have a spark plug socket.
Paxovasa
PostPosted: 11:16 - 26 Jun 2011    Post subject: Reply with quote
Oops double post. Embarassed
Vexon101
PostPosted: 11:17 - 26 Jun 2011    Post subject: Reply with quote
If you have the took kit for the bike, you should have a spark plug socket.[/quote]
I don't have It anymore, the owner I bought off said the previous owner had lost It. What can I use as a substitute? Or should I buy a new one?
Paxovasa
PostPosted: 11:20 - 26 Jun 2011    Post subject: Reply with quote
It will be awkward without a plug socket. not much room to get a spanner in to.
This is a plug socket:
https://www.toolbuddy.co.uk/ekmps/shops/toolbuddy/images/newsome-tools-21mm-spark-plug-socket-1-2-dr-3495-p.jpg
alains
of course , you may use a 21 spanner or specific sparkplug tube wrench
Vexon101
PostPosted: 11:25 - 26 Jun 2011    Post subject: Reply with quote
Just looked, haven't got a spanner big enough, wrench Is too big to get It off so I suppose I'll have to buy one specifically for the sparkplug, may as well buy a spark plug while I'm at It just In case.
Is this one fine https://www.amazon.co.uk/gp/product/B0012M7N9Q/ref=s9_simh_gw_p263_d0_i2?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=center-2&pf_rd_r=0PSD55TJDZJN6P3SQ5VP&pf_rd_t=101&pf_rd_p=467128533&pf_rd_i=468294
Paxovasa
PostPosted: 11:31 - 26 Jun 2011    Post subject: Reply with quote
It need to be the same size as the spark plug. So if your saprk plug is 21mm then the socket has to be 21mm.
Vexon101
PostPosted: 11:48 - 26 Jun 2011    Post subject: Reply with quote
I'll be borrowing one tonight, I'll make another topic If I've got any problems
alains
PostPosted: 13:30 - 26 Jun 2011    Post subject: Reply with quote
you must have the tool kit under your seat !
The last post was made 15 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 127.87 Kb
