aprilia rs 125 help. *urgent*
leepick
PostPosted: 21:57 - 24 Jun 2011    Post subject: aprilia rs 125 help. *urgent* Reply with quote
hi
well...
i took the engine out of my rs125 removed the crank shaft took the crank to the garage with a new con rod and bearings which they fitted for me, bought the crank back and put it back into my engine. now the engine is back in my bike when the bike is running the bike shakes a bit... not a smooth ride at all. could do with some help some tips and just some of your thoughts please...
will the shaking stop once ive run the bike in a few miles?.
do i have to take the engine back out?
is there an easy way to solve this ''problem''
thanks in advance for your replies.
Aprilia RS125
Truzo
PostPosted: 23:05 - 26 Jun 2011    Post subject: Reply with quote
Shaking like that is normally due to bad main bearings or dodgy engine mount rubbers/brackets.
As you had your crank out i would say that its quite likely that may be your problem.
Try all your engine mounts first. as that is a lot easier.
Not 100% shure but thats what i have had experience with.
Current Bikes: RXS 100, RD 125lc3, RD 350 F2
PostPosted: 00:55 - 27 Jun 2011    Post subject: Reply with quote
Dude, the shaking is either your balance shaft or loose engine mounts... more than likely the balance shaft if you just popped it in the first way it fitted.
The last post was made 14 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.9 - MySQL Queries: 13 - Page Size: 35.32 Kb
