Say some idiot puts things that shouldn't really go...
PostPosted: 08:21 - 27 Jun 2011    Post subject: Say some idiot puts things that shouldn't really go... Reply with quote
in a dishwasher in a dishwasher. Now my DW smells like turps. How do I fix this before my mum kicks the shit out of me. Embarassed
PostPosted: 08:23 - 27 Jun 2011    Post subject: Reply with quote
Put it on again with nothing in it except the dishwater tablet.
Hopefully it'll clear itsself.
Or fill it up with something even more strong smelling. Like dirty plates from a curry.
Skudd
PostPosted: 08:24 - 27 Jun 2011    Post subject: Reply with quote
Break a window.
Then she won't notice the smell because she will be going ape over the glass.
PostPosted: 08:32 - 27 Jun 2011    Post subject: Reply with quote
It has at 3 runs on empty at top temparature. Still stinks Sad
Considering the windows are only about 6 months old I think I'd rather take my chances with the DW.
Robby
Dirty Old Man
PostPosted: 08:34 - 27 Jun 2011    Post subject: Reply with quote
If it has a sump with any liquid in, drain it down or get the water out somehow - even if it means dipping a cloth into it and squuezing the water out into a bucket.
Then a long hot wash with detergent to break down and emulsify and remaining turps, and open the door as soon as possible afterwards so that the steam coming out will also let all of the turps steam/evaporate out and not condense inside the machine.
Then do something involving turps in the kitchen, so the smell of turps can be attributed to whatever you are doing and not the machine.
If this fails, you end up buying her a dishwasher and you have the old one to use as a parts washer in the garage. Double win.
PostPosted: 08:39 - 27 Jun 2011    Post subject: Reply with quote
Blame it on someone else?
PostPosted: 08:43 - 27 Jun 2011    Post subject: Reply with quote
Hmmm I can't see my mum buying that out of me and my Sister she was the one to make it smell like turps Laughing
Good ideas Robby I will do this. Thumbs Up
mad4it028
PostPosted: 08:48 - 27 Jun 2011    Post subject: Reply with quote
bleach ?
neil.
PostPosted: 09:03 - 27 Jun 2011    Post subject: Reply with quote
Cup of white vinegar in there, run on hottest cycle?
Or sprinkle some baking soda in and run it on the hottest cycle?
Not at the same time though...
Use the vinegar method myself once a month or so to get rid of the smellyness but not sure how well it'd work on turps.
PostPosted: 10:20 - 27 Jun 2011    Post subject: Reply with quote
Silly point won't it stink of vinigar then?
JP7
PostPosted: 10:26 - 27 Jun 2011    Post subject: Reply with quote
You can get deodorant or odour neutraliser fluids, pop to the supermarket and grab one of those and see what that does. Apparently they're quite good.
Hetzer
PostPosted: 10:27 - 27 Jun 2011    Post subject: Reply with quote
Squirt a complete bottle of washing-up liquid into it. And a box of washing powder. Thumbs Up
PostPosted: 10:52 - 27 Jun 2011    Post subject: Reply with quote
This but with pictures! Laughing
Frost
PostPosted: 11:06 - 27 Jun 2011    Post subject: Reply with quote
Baking soda in the powder draw, then put a bowl full of vinegar into it. That'll clean it out a treat.
PostPosted: 12:48 - 27 Jun 2011    Post subject: Reply with quote
I need more Lemon Pledge.
tatters
Exxon Valdez
PostPosted: 13:31 - 27 Jun 2011    Post subject: Reply with quote
https://24.media.tumblr.com/tumblr_lgx9wlkVhG1qho62eo1_500.png
Kris
PostPosted: 14:19 - 27 Jun 2011    Post subject: Reply with quote
Put a capful of white wine vinegar in the bottom of the dishwasher and set it to rinse cycle.
What did you put in there? Laughing
www.prisonplanet.com
PostPosted: 15:04 - 27 Jun 2011    Post subject: Reply with quote
Well to start with I put in all the black plastic from my TDM the Chain guard/hugger, fairing infills etc.
Now bearing in mind this bike is never washed the chain guard was filthy. After a 70 degree was it was 90% clean another wash had it 99% clean. I took them out and let them dry. It had obviously taken it's toll on the machine as it was slightly dirty inside and when I pulled the trays out it felt like all the runners where on grit. I put a couple of cycles through to clean it up. At the same time that these where washing I had my mums mixing bowl half full of turpentine. I was cleaning up all the nuts and bolts on my TDM in the Turps then putting them in my Ultrasonic cleaner with some vinegar. After I finished I drained the Turps (down the sink) and though fuck it why not shove the bowl in the dishwasher (it was on the first rinse after I took the plastics out.) When I went to take the bowl out I opened the DW and was punched in the face by the smell of hot turps, I decided to write the mixing bowl off and make sure the DW was OK. I think it has had 2-3 rinses since and still stinks. Embarassed
Worse thing is the kitchen is about 9 months old and the dishwasher is built in.
Bendy
Mrs Sensible
PostPosted: 16:00 - 27 Jun 2011    Post subject: Reply with quote
You need to find the source of the smell.
Have you looked into robby's suggestion about the 'sump'?
He means the water softener (if your model has one). I could see there being a film of turps floating on top of the water that's in there...
Are there any plastics in your dishwasher? Can you take those bits out?
I presume you've taken the filters out and cleaned them?
Hetzer
PostPosted: 16:40 - 27 Jun 2011    Post subject: Reply with quote
All plates and stuff that are washed in it now will smell of turps, and any food served from those plates will smell and taste of turps. You are going to be so busted.
As you're already going to be in a world of pain why don't you pull the dishwasher out, fit a turbo and go spank it up the motorway?
PostPosted: 16:52 - 27 Jun 2011    Post subject: Reply with quote
Look for it with a lit match Thumbs Up
Hetzer
PostPosted: 17:02 - 27 Jun 2011    Post subject: Reply with quote
The turps won't light by itself but that's a good idea Shaggy. Put some gasoline in it to get a burn going, that'll also burn off the turps and all the horrid smells will be gone. Take all the plastics out first of course, only a dumbarse would leave those in.
Kwaks
I'm not a fast rider
PostPosted: 18:23 - 27 Jun 2011    Post subject: Reply with quote
take off the u bend and clean it out, running the tap wont suffice as the turps wil sit on top of the water
www.cliqueycuntsmcc.co.uk
PostPosted: 18:45 - 27 Jun 2011    Post subject: Reply with quote
I'd go:
Clean U-bend.
Take everything possible out of the dishwasher.
Squirt and rub a whole bottle of fairy liquid (get the good stuff, your life depends on it) all around the dishwasher and into its drain.
Cold rinse.
Ventilation: blow a fan into it and open the doors and windows.
Shut a cat in it for a few hours - cat pee masks anything.
Suntan Sid
PostPosted: 19:03 - 27 Jun 2011    Post subject: Reply with quote
After cleaning, by whatever method, buy some BBQ charcoal, place some in a bowl and leave the bowl in the DW whenever it's not in use!
The last post was made 15 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 130.13 Kb
