Rough Running so plug chop done - what next
HoggyF
PostPosted: 12:59 - 27 Jun 2011    Post subject: Rough Running so plug chop done - what next Reply with quote
Been trying to sort the bogging down on my sones pit bike so carried out a plug chop yesterday, full throttle up a lane through the gears and the result was
https://i541.photobucket.com/albums/gg365/HoggyF/IMAG0298.jpg
The original problem was that it bogs down when you open the throttle fully open from tickover I.e. a big blip, other than that it rides quite nicely but it did feel aq little bit weak at the top of the revs.
Engine is brand new but carb is off the old engine and we don't know the spec of either engine so it is quite likely that the new one could have different size valves etc.
I think the plug looks a little bit rich but previous advice with it bogging down was that it would be the pilot jet???
What to try next??
PostPosted: 13:47 - 27 Jun 2011    Post subject: Reply with quote
Letting us know what sort of bike it is might be a good start! Wink
neil.
PostPosted: 14:04 - 27 Jun 2011    Post subject: Reply with quote
Looks lean to me - white ceramic bit.
HoggyF
PostPosted: 14:09 - 27 Jun 2011    Post subject: Reply with quote
Bike is a pit bike with Loncin 125 engine
plug is brand new so that probably explains the white bit, the circular end of the threaded section is quite sooty to my mind and not the nice coffec colour I had hoped for.
temeluchus
PostPosted: 20:18 - 27 Jun 2011    Post subject: Reply with quote
Its the condition and colour of the tip your interested in. It does look lean as the tip is rather shiny and white.
Rich running or over oiling would make the whole lot black and sooty.
hazza
PostPosted: 10:59 - 28 Jun 2011    Post subject: Reply with quote
Running Lean would also explain the bogging from tick-over to full throttle.
HoggyF
PostPosted: 12:28 - 28 Jun 2011    Post subject: Reply with quote
So if its running lean does that mean adjusting the needle or going up a size on the main jet.
Anyone know where to get jets for a TaoTao pitbike carb?
I remember from yrs ago a car engine tuner used to drill out his jets or solder them up then re-drill, anyone tried this?
hazza
PostPosted: 13:29 - 28 Jun 2011    Post subject: Reply with quote
I would start with jets first. I once brought a carb off a thumpstar pit bike to fit on my C90, i couldnt find any different size jets so i still have that carb now, although the c90 is long gone. They seem to be difficult (at the time anyway) to get hold of. I wouldnt recommend soldering/drilling out jets. They are precision pieces of kit and id be suprised if you had any success at all with this method.
As for sourcing jets, Ebay is probably your best bet mate Thumbs Up
PostPosted: 13:32 - 28 Jun 2011    Post subject: Reply with quote
Adjust the mixture screw first, I'd be doing that before rejetting.
Could just be the wrong mixture...but does look overly lean, I wouldnt be happy running on that at all..
HoggyF
PostPosted: 13:44 - 28 Jun 2011    Post subject: Reply with quote
Tried mixture screw, doesn't make much difference although it gets slightly less "boggy" as you get nearly all the way in then another slight turn and it starts to die.
temeluchus
PostPosted: 07:44 - 29 Jun 2011    Post subject: Reply with quote
It wont, thats only for the idling circuit, once you get much above idle it will have little effect.
It always makes me giggle when the inexperienced think pissing around with the idle mixture screw will cure all carburetion ills X-)
HoggyF
PostPosted: 12:56 - 29 Jun 2011    Post subject: Reply with quote
Temeluchus - glad to see we are amusing you - I'm not having a go but saying something like that isn't really that helpfull unless you continue to give usefull advice as to how to solve the problem, everyone has to learn somewhwere.
I allready knew that it wouldn't solve the problem but at least Paddy was trying to help
The last post was made 14 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 72.58 Kb
