| Stelmer |
 Stelmer World Chat Champion
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 13:24 - 27 Jun 2011 Post subject: |
I'd buy at least one donor engine, myself. If the GS I'm working on were in worse nick, with a higher mileage, I'd have done so already.
Personally, unless the donor engine was in significantly better nick (i.e. running sweetly, with no untoward noises/smoke), I'd tear down the engine you know works, and renovate everything that needs it. THat way you've got a proven engine, with all necessary repairs/replacements done, so it'll be good for a while yet. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| Ichy |
 Ichy World Chat Champion
 Posted: 13:28 - 27 Jun 2011 Post subject: |
You can't guarantee that the replacement engine will be any better. If it is just a couple of puffs then I'd ride it for now and keep an eye on the oil level. Start searching for bits to overhaul it come Winter.
Its the rebore that will eat up the money so maybe search for a replacement head, barrels and pistons as opposed to a full engine. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| finpos |
 finpos World Chat Champion
| truslack |
 truslack World Chat Champion
| Robby |
 Robby Dirty Old Man
 Posted: 17:34 - 27 Jun 2011 Post subject: |
If you change the engine, then it would make sense to pull down the new engine prior to fitting to check the condition of the rings, grind in the valves, and fit new seals and gaskets - inc valve stem oil seals, which are probably one of your current problems.
Seeing as you're going to do all of those things, it's worth pull the existing engine apart now. If the current engine is knackered, then stripping it is practice. If the current engine is ok, then stripping it means you fix it.
Are you very sure that the piston rings are shot? In my experience it takes dedication to wear out the piston rings on a 4 stroke, the valves will be covered in carbon and their stem seals shot well before the rings wear. Valves can be reground at home, and stem seals come as part of the £30 pattern gasket kit. You can measure the ring end gap while its all apart as well, so see if they really are worn. |
| temeluchus |
| Stelmer |
| temeluchus |
| virus |
 virus World Chat Champion
 Posted: 19:22 - 27 Jun 2011 Post subject: |
Do a compression check and note the PSI, then add a teaspoon or so of oil down the plug hole and do it again, If the PSI rises dramatically then you can be fairly certain its rings. Id hazard a guess that a second hand engine would be cheaper than new rings on all 4 pots but as has been said, check your new engine over before paying too much for one.
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| Casper |
 Casper World Chat Champion
The last post was made 15 years, 1 day ago. Instead of replying here, would creating a new thread be more useful? |
