Fork seals.
carlosthejack...
PostPosted: 19:41 - 27 Jun 2011    Post subject: Fork seals. Reply with quote
How will I know if my fork seals are leaking on my '05 Hornet? My right upper fork leg has a bit of dirty smearing on it above where it goes into the lower, and the right hand side of my tank is spattered with fluid when I get to work. There's nothing running down the leg and the dust seal is intact. Feels ok too. I'm taking it back to the shop tomorrow for them to have a look at, but I was wondering if I need to? Does it sound like a leak or am I just being paranoid?
I'm saying it feels ok, it does feel a little 'juddery' under hard braking. Maybe not juddery as such, but not ultra smooth like I thought it would. Again, am I being paranoid?[/img]
duhawkz
PostPosted: 20:20 - 27 Jun 2011    Post subject: Reply with quote
I usually lift up the dust seal out of the way, wipe the forks clean then bounce the front a couple times then check if there is any oil on the forks or round the seals
Casper
PostPosted: 20:29 - 27 Jun 2011    Post subject: Reply with quote
Its gone mate. Get them changed.
carlosthejack...
PostPosted: 20:41 - 27 Jun 2011    Post subject: Reply with quote
Just been and done that and yes, the right leg is smearing with oil after bouncing it.
I'm assuming that's what's causing the 'notcht' feeling under compression and braking? It feels clicky when I'm bouncing it.
Quote Me Happy
PostPosted: 20:45 - 27 Jun 2011    Post subject: Reply with quote
Check the headstock bearings as well as well as wheel bearings.
Willson
PostPosted: 21:10 - 27 Jun 2011    Post subject: Reply with quote
If you have floating discs that could be the notchyness/click. It is on my SV, the disc can move back and forward slightly.
Willson
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
PostPosted: 22:16 - 27 Jun 2011    Post subject: Reply with quote
Might just be dust under the seals.
I only found this out recently and now wonder how many sets of perfectly good fork seals are changed every year because of a smear of oil on the stanchion.
If there is no pitting or marks on the stanchions, the seal should be ok. You can clean the dust out from underneath it by wrapping a thin, rigid piece of plastic film round the stanchion and pushing it down past the seal a couple of times. Photographic negatives are perfect for this.
My finacees CB500 was leaking so much oil from the seal it was starting to run down the fork leg. Did the film trick and it's still dry as a bone 1500 miles later.
delsol
PostPosted: 06:39 - 28 Jun 2011    Post subject: Reply with quote
Hi stinkwheel,
Can you give a link to the 'film trick', I'm assuming it has already been posted.
Thanks,
delsol
PostPosted: 11:44 - 28 Jun 2011    Post subject: Reply with quote
delsol wrote:
Hi stinkwheel,
Thanks,
delsol
That's it, as I described in the post.
You wrap a piece of thin but rigid plastic tightly round the fork stanchion just abover the seal. I use a piece of photographic film. You then slide it down past the seal a couple of times. Cut the plastic to length so it wraps round the stanchion once, no doubling up.
carlosthejack...
PostPosted: 12:33 - 28 Jun 2011    Post subject: Reply with quote
All changed, nice as pie now!
PostPosted: 12:27 - 12 Jul 2011    Post subject: Reply with quote
BUMPing to thank Mr Wheel for another excellent bit of advice.
Stanchion drenched in oil Arrow pop dust seal off Arrow wiggle a feeler gauge around the oil seal Arrow dry stanchion.
Magic, many thanks. Thumbs Up
The last post was made 15 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 72.16 Kb
