Honda CBR600F swingarm replacement.
Willson
PostPosted: 21:09 - 27 Jun 2011    Post subject: Honda CBR600F swingarm replacement. Reply with quote
When Benson_JV told me he'd knackered his swingarm (See here) I knew I was going to have to fix it.
First thing we did is forget the Haynes manual, but luckily it was quite simple to figure out: Remove chain guard/hugger, remove rearsets for easier access, remove side panels, seat and rear fairing for easier access, remove exhaust (needed changing for MOT, also easier access), drop out back wheel and remove calliper, unbolt shock linkage, unbolt shock from swingarm (we did these two the wrong way around, because I'm a plank), unbolt swingarm.
The reassembly is essentially the reverse of the above, but with the added bonus of chain tensioning and wheel alignment (we did the chain up a tad tight).
As this thread would be absolutely worthless without pics, here are some!
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0646.jpg
Chain guard and hugger off, screws back in their original holes
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0647.jpg
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0648.jpg
Rearsets, rear brake master cylinder and reservoir off
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0649.jpg
Topless Benson_JV. Scary I know.
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0650.jpg
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0651.jpg
Back wheel and brake calliper out. In the orange bag is the rear wheel spindle (we're organised like that)
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0652.jpg
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0654.jpg
Removing shock linkage from swingarm. We should have removed the bolt above it first to make life easier. Also, note the plastic bag in the exhaust: If something CAN drop down somewhere, it WILL drop down somewhere.
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0653.jpg
Swingarm nut.
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0655.jpg
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0656.jpg
Old swingarm out. Picture time!
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0657.jpg
Break over, new swingarm in. Didn't have any proper grease so sprayed the spindle with some silkolene chain gel.
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0658.jpg
Shock linkage bolted back in.
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0659.jpg
Back wheel back in, that's me buggering about with the rear brake system.
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0660.jpg
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0661.jpg
Not a bad job eh?
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0662.jpg
Finally bolting the right hand peg back on.
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0663.jpg
https://i1137.photobucket.com/albums/n510/isoisawillson/IMG_0664.jpg
Chain guard and hugger back on.
After that we refitted the side panels, seat and rear fairing, mounted the stock exhaust back on and rode from Wythall to Tipton for an MOT. That passed with advisories on the rear pads (they're running low) and the chain was a little tight.
All in all not a bad day!
Willson
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
Benson_JV
PostPosted: 22:06 - 27 Jun 2011    Post subject: Reply with quote
Bostin. Cool
All that's left to do now is fit the other zorst, replace pads and re-tension that chain!
Willson
PostPosted: 22:08 - 27 Jun 2011    Post subject: Reply with quote
No Benson... full strip and clean of that calliper Wink
Willson
supZ
PostPosted: 08:58 - 28 Jun 2011    Post subject: Reply with quote
thought this was going to be replacing the swingarm with an RR one or something ;(
CBR954RR - Daily toy
CBR600RR - Trackbike
Kris
PostPosted: 13:05 - 28 Jun 2011    Post subject: Re: Honda CBR600F swingarm replacement. Reply with quote
Remember kids, whenever you slacken off the rear spindle and subsequently retighten - you must check that the chain adjusters are tight.
The local garage forgot to do this on a mates bike; his chain adjuster plates are in a bush somewhere in the South of France.
www.prisonplanet.com
PostPosted: 13:19 - 28 Jun 2011    Post subject: Reply with quote
If you want rid of the Swinger Steven_191 might want it as he is putting a CBR rear end on his Mito 640 project.
porndoguk
PostPosted: 14:02 - 28 Jun 2011    Post subject: Reply with quote
i also have a load of CBR600F Spares, as weve just done and engine Transplate as the brothers head BLEW UP last friday :S
we bought a Cat C write off, front smash,
Rick
The last post was made 15 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 57.46 Kb
