cant locate brake switch
kerr
PostPosted: 23:00 - 28 Jun 2011    Post subject: cant locate brake switch Reply with quote
went to a bike mechanic to ask about looking at the brake light, as i stated in one of my previous threads the back light works but not the brake light.
he said chances are its the brake switch and to follow the connections from the front or rear brake to try and find it, for the life of me i cant find a switch anywhere.
does anyone know where it is, or even what it looks like?
see my sig for bike model
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
Bezzer
PostPosted: 23:10 - 28 Jun 2011    Post subject: Reply with quote
Have you checked the bulb first?? if it's not working on either brake it might be that and save a lot of digging round the wiring.
kerr
PostPosted: 23:15 - 28 Jun 2011    Post subject: Reply with quote
that was the first thing i checked, bulb is fine. i replaced it anyway just incase, still no workie Sad
desperate to get a good run in the bike cause i think it needs one but i really dont want to chance running about with no brake light.
Bezzer
PostPosted: 23:21 - 28 Jun 2011    Post subject: Reply with quote
It should have seperate switches on the front and rear brake lever/pedal, not likely that both have failed at the same time so you're looking at tracing the wiring back from the light looking for a break/duff connector. Take it you haven't got a wiring diagram.
MickC
PostPosted: 23:22 - 28 Jun 2011    Post subject: Reply with quote
the front one is usually a micro switch in the brake leaver the rear one usually conects to the brake pedal...it maybe behind the frame and check your fuses it could be that
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
kerr
PostPosted: 23:27 - 28 Jun 2011    Post subject: Reply with quote
had a look all over cant find a broken connection a fair amount of bodged connections ie: insulating tape.
havent got a wiring diagram, where would i get one? although id probably not be able to make head nor tale of it, electrics isnt my strong point but the last thing i want to do is get an auto spark at ££ per hour for something that is probably a simple fix.
the bike passed an mot not long ago so must have been working at some point, guy i bought it off mentioned he replaced the rear pads so maybe he took something out and forgot to put it back in? but like i said i cant find anything disconnected
kerr
PostPosted: 23:29 - 28 Jun 2011    Post subject: Reply with quote
how many fuses does a bike usually have? i can only find 2 next to the battery, both are fine.
MickC
PostPosted: 23:37 - 28 Jun 2011    Post subject: Reply with quote
It does vary, mine has one next to the battery and four mounted under a cover on the handlebars (but mine is a larger bike). Had one a few years ago that had five mounted under a cover on the front fork brace (the whole assembly used to rot to hell because of rain and shit hitting it full on - nice one yamaha!)
XX XXXx
Frost
PostPosted: 23:43 - 28 Jun 2011    Post subject: Reply with quote
If it comes on from the front brake but not the rear then the rear switch just needs adjusting. If it comes on from neither it's either the fuse or wiring. A soldering iron, length of wire and a spare hour or 2 will have it fixed.
kerr
PostPosted: 23:47 - 28 Jun 2011    Post subject: Reply with quote
neither works, an hour or 2 for you maybe, il be there all day Laughing
MickC
PostPosted: 23:49 - 28 Jun 2011    Post subject: Reply with quote
If you don't have a manual it says there is a free download of it here:
https://www.apriliafutura.co.uk/v2/index.php?view=article&catid=34:servicing&id=98:workshop-manuals&format=pdf
Not sure if it is the one for your bike but its worth a go.
XX XXXx
kerr
PostPosted: 23:53 - 28 Jun 2011    Post subject: Reply with quote
currently downloading, il let you know how i get on Thumbs Up
on a side note, how do you check the oil level, surely you dont have to take the fairings off ?
MickC
PostPosted: 23:57 - 28 Jun 2011    Post subject: Reply with quote
Its usually a dip stick mounted in the top of the engine case or it might just have a cap and a viewing window, But i've never owned that model so can't say for sure. If the manual is the right one it will tell you how to check it in the routine mountance section.
XX XXXx
The last post was made 15 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 76.75 Kb
