Pain in hand
Wilson12345 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Robby
Dirty Old Man
PostPosted: 06:35 - 29 Jun 2011    Post subject: Reply with quote
It started after getting the R6, so there's a possibility. If you're resting on that joint rather than your palms there's a lot of force going through it and it's a fairly delicate joint (small joint, big range of movement). Riding more and carrying stuff isn't going to help the problem fix itself.
The obvious way to diagnose is to not ride the R6 for a month or so, but that isn't going to happen. You should be resting on your palms, so see if you can adjust the clips on out a bit to spread the load more. If they're angled in too much then the weight will be going through the inside of your hands, between your index finger and thumb.
Or just man up and get a Harley, no weight through your hands at all.
PostPosted: 07:27 - 29 Jun 2011    Post subject: Reply with quote
That reminds me, I'm going to the doctor to ask about adjusting my clutch cable.
Get it checked out by a professional, you spacker!
PostPosted: 13:56 - 29 Jun 2011    Post subject: Reply with quote
There actually is a very small bone there in some people called a sesamoid bone, embedded in the flexor tendon. More common to have one at the thumb joint but there is occasionally one at the second metacarpophalangeal joint too.
It can become inflamed which I suppose would be called second metacarpophalyngeal sesamoiditis.
duhawkz
PostPosted: 14:51 - 29 Jun 2011    Post subject: Reply with quote
sounds like over vigorous self gratification to me,
lets face it you are a massive wanker Wink
The last post was made 15 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 55.34 Kb
