No fuel going into carbs?
damz
PostPosted: 18:16 - 29 Jun 2011    Post subject: No fuel going into carbs? Reply with quote
I have just moved house and my bike was in storage for around a month before it was brought over and it wont start now. I recharged the battery, checked the plugs (all clean and dry) drained the carbs and checked the fuses and it still wont start.
Now im thinking that there is no fuel going into the carbs now as the fuel house that leads into the carbs doesnt appear to have petrol in it when i disconect the cable from the carbs.
forgot to say this is for a kawasaki zx7r. Any suggestions on what to try?
had to be sods law that the bike that has tax, mot and insurance is the bike that wont start and the bike that has none of those starts first time Sad
Current Bikes RVF400 - 94
Cars: RX7 FD, Eunos Roadster
MickC
PostPosted: 18:42 - 29 Jun 2011    Post subject: Reply with quote
Try removing the petrol cap and then try to start it, if it runs ok then you most likely have a blocked tank breather
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
Marmalade
PostPosted: 19:49 - 29 Jun 2011    Post subject: Reply with quote
There may be a push button near or on the tap to bypass the vacuum valve and allow the fuel to flow and fill the carbs
One it runs it'll work as long as the valve and pipe are both ok
damz
PostPosted: 15:52 - 01 Jul 2011    Post subject: Reply with quote
The tank has at least 5 litres in it as i thought this was the problem so filled up a jerry can. Still wouldnt start, sucked the fuel hose and some petrol came out but only a tiny bit, fuel tap is fine since i pulled the hose out petrol came out. So i think the fuel pump just isnt doing anything now. Any way to find out if this is indeed the cause of the problem?
The last post was made 14 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 44.12 Kb
