lube
blahheed
PostPosted: 15:34 - 30 Jun 2011    Post subject: lube Reply with quote
what is the best chain lube to use ?
neil.
PostPosted: 15:38 - 30 Jun 2011    Post subject: Reply with quote
I've started recently using 90w gear oil (The bike manual actually recommends it and it works out cheap). Doesn't fling as much as the 10w40 engine oil that I was using previously, but aside from that, 10w40 was just fine.
DrDonnyBrago
PostPosted: 15:39 - 30 Jun 2011    Post subject: Reply with quote
Oil.
Engine (used or new - any thickness you can get), gearbox or chainsaw oil.
Thicker is better as it doesn't fling off as bad but any will be fine.
deleted111
PostPosted: 15:40 - 30 Jun 2011    Post subject: Reply with quote
As above, oil is fine.
Currently I'm using some Holt's chain lube stuff I got from Halfords. Seems like alright stuff.
PostPosted: 15:41 - 30 Jun 2011    Post subject: Reply with quote
I also use engine oil.
I used to use EP90 gearbox oil when it was handy but I don't have a bike that uses it any more so I use old sump oil I've drained from the bike at an oil change.
Frost
PostPosted: 15:59 - 30 Jun 2011    Post subject: Reply with quote
https://www.vibetastic.co.uk/images/E20675.jpg
Or you can get chain lube in an aerosol that's very good, comes out with a sticky foam, stays on the chain very well.
neatbik
PostPosted: 18:17 - 30 Jun 2011    Post subject: Reply with quote
I use a Tutoro chain oiler with whatever oil i have lying around.
Seems to do the trick.
SirEdward
PostPosted: 18:24 - 30 Jun 2011    Post subject: Reply with quote
Cinnamon - u mad, sir?
"Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune""
kramdra
PostPosted: 20:18 - 30 Jun 2011    Post subject: Reply with quote
This. I need to oil my new chain.
I dont like aerosols. It stays on and collects dirt, and needs too much cleaning. Im not going to use it on new bike.
Im going to give the chain a first coating of used oil later, and every journey until i get a proper automatic thingy sorted.
potato
PostPosted: 22:32 - 30 Jun 2011    Post subject: Reply with quote
I got some wurth wax atm.
OOOooosshh!
Johnser
PostPosted: 14:16 - 01 Jul 2011    Post subject: Reply with quote
I think the general idea is that some is better than none and a clean chain with fresh oil is better than riding with old crunchy stuff rolling about - essentially like grinding paste after a while.
I have been using a mix of gear oil and waxoyl. the idea being that the waxoyl would have white spirit in it that'd help let the oil creep into the chain but would then evaporate to leave it there and the gear oil would help with the "extreme pressures".
whatever you decide, be wary of flinging too much lubricant onto rear wheels
The last post was made 14 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 71.42 Kb
